fgs
    4
Everything posted by fgs
  1. It seems as it was "terminated"? I assume the nylon gear is stuck inside (see picture 2) was a bit hard to get a better look.
  2. I don't have the proper equipment to jack the car up but when the car was on the hoist at my mechanics, he said it was the actual gear inside the gearbox that was missing, didn't mention anything about the speedo cable assembly. i could probably just pull the trigger on the highlighted parts and see how it goes?? What are your thoughts ? cheers again Banjo!
  3. I believe it's from a KE55, it doesn't look like it's far back. Mission is trying to figure what tooth/worm combination. Something tells me it's 6x?? I've found this diagram of a k50 (ke35) and I've highlighted what I think I need...
  4. Hi all, I have recently bought a 1979 KE55 corolla, it has recently been changed to a 5 speed manual (K50) from a 3sp auto (K40?) and since then the speedometer/odemeter does not work. It has the speedo cable but is missing the speedometer drive gear and key/ball in the gearbox. It is running the same diff but I'm unsure of ratio. I've think I've found the necessary parts list for transmission: http://www.toyodiy.com/parts/p_G_1979_TOYOTA_COROLLA_KE55R-EMRQ_3304.html and http://www.toyodiy.com/parts/p_G_1979_TOYOTA_COROLLA_KE55R-EMRQ_3305.html If anyone could shed a light, I don't really care if it's a little bit out as long as it works. cheers for reading!
