keith
    8
Everything posted by keith
  1. keith red ke55 corolla with 4k hi just new
  2. hi mate have a 5k work van. was a 4 speed. was told that a 5 speed gear would fit in the box. did not happen but yes a 5 speed box will fit. good luck
  3. yeah this means that you rings are worn or bore polished. and the compression is getting past your compression ring and in to you crank case. might need rebiuld soon. 4ks are easy small bit of knowlege and tools and your sweet to do it. basic engine. good luck
  4. mainly for tas_ae71 but every one as well. don't need a plug test for a car with OUT a ecu you can just hook a spark plug up the leed and let the electrod or thread rest on the engine. on the metal for an earth. (not a good idea if you have an ecu). if your plugs look bad replace them only $2.50 each
  5. hi mate if you have an exhaust or in let leak check if there warped and true if they are a bit not too much try putting 2 gaskets on and rgv selastic high temp. cost you about 20 dollars and the hassle of taking it off again
  6. hi every the name is keith. Live in penrith. i have a ke55 corolla. let me no if any cruisers in area. got a worped exhaust manifold so sounds crap. organising secound engine but so not replacing embarised. 4th year mechanic apprantice so need help just ask and i will see if i can help.
  7. Thanks to all that replyed to my guestion. Will look in to the 4ag engine. forgot to interduce my self. keith from penrith sydney with a ke55.
  8. hi guys i need help can't find info in search. i need to rebiuld my 4k engine in a couple of weeks. i was thinking of working a second 4k engine un till a friend surgested putting in a corona engine. has anyone got any surgestions. not to good electrical so wont to stay carbi. other engines will be good.
