Sudden
    8
Everything posted by Sudden
  1. with my high compression, i thought my 26 degrees was conservative! 25 on that motor surprises me.
  2. I meant in response to you not wanting cams that require a higher rev limit.
  3. no intentions to rev past 6500? :( awwww. the right cam selection should widen and raise the powerband with minimal low end torque loss, its a 2.4 after all
  4. going to explore how high you can rev the stock bottom end?
  5. sounds amazing
  6. failing check valve?
  7. hey, what are your thoughts on slide style throttles? and making your own to suit the intake port/ size you want? sorry for double post thought I was on the direct message chat. how do I delete these? D:
