dootie
    14
About dootie
  • Birthday 11/06/1999
  • Location
    bairnsdale
  • Interests
    carz
  • Real Name
    Lochi
Recent Profile Visitors
4263 profile views
dootie's Achievements
  1. Yeah alright will do. Cheers
  2. I might just take them somewhere that specialises in suspension I think. I don’t really know what lm looking at when it comes to shit like that. Cheers for the feedback!
  3. Nah the only photos I have are the ones he sent me before I bought them. They are hsd coilovers so i would think the camber tops should be properly fitted. Hopefully there not rooted
  4. well I’ll be a bit pissed of if there rooted. I payed an arm and a leg for them in good faith. Turns out I’ve probably been jibbed. I’ll most likely just put my old stuff back in and hunt for some new coilovers if these ones are fucked I think. Do you know where I would be able to source parts for hsd coilovers from? cheers
  5. So the those top nuts that are holding the strut insert in the coilovers or whatever are ok? I was just a bit worried cos one looks like it’s been fully cranked tight and the other like it’s backed right off. Also there’s a knocking sound coming from both coilovers and I was wondering if they were the cause. Cheers
  6. I just put some second hand ae86 coilovers in my ke70 and I was wondering if the strut tops are meant look like this. Cheers
  7. as u suggested when i looked down the spark plug holes with a light i could see small signs of carbon on top of the pistons. i used a little bit of compressed air to try blow some of the carbon that was easily visable. it started to turn over with out a problem so we decided to just put it back in. it is now back i the car and running. the engine seems to be running very well and i havent had a problem with it since its been back in the car. thanks again for all the reply's.
  8. will do. cheers!
  9. thanks for the info guys. turns out that there was carbon on top of the pistons that was causing it to lock up.
  10. yeah i might just have to start pulling the engine apart and see if i can find the problem.
  11. i only removed the engine because 2 of the bolts were snapped and i thought it would be easier to just remove the whole engine rather than take just the head off.
  12. i didnt need to remove the head as it was only the plate on the rear that needed fixing.
  13. to start things off i bought the car not running as it was leaking from the plate at the rear of the head. the previous owner did drive as his daily up until it started leaking. i then took the motor out and fixed it. after that i put the motor back in the car then i tried to start it, it turned over then locked up. the motor is now out of the car with no gear box attached though when i try to manually turn the crankshaft it will turn 360deg one way then lock up, i can then turn it 360deg back the other way before it locks up in the same spot. cheers
  14. 4k will turn over but locks at the same spot each time.
