kevin
    20
  • Real Name
    kevin
Recent Profile Visitors
248256 profile views
kevin's Achievements
  1. Hi does anyone know from what car make front right hub will fit ke70. Having difficulty finding one.
  2. will it be costly to convert my standard 3t motor from carburetor to fuel injection. what all is required and estimate cost
  3. please also advise. I want to fit 4-door electric windows in my ke70. will any electric windows stripped for another vehicle work? was thinking if the toyota ae92 twincam models work.
  4. please advise 3t motor auto and manual gearbox. will the auto and manual flywheel work or is there a difference? i have a manual box so must i get manual or it doesn't matter
  5. just a follow up. I went to test my flywheel to determine why flywheel bolts keep coming off. the reason is that my flywheel is warped? can an engineering place make this straight or do i need to get another flywheel?
  6. Please advise if a bmw e30 conversion will work on Toyota ke70 engine fitment ? gearbox ? brake upgrade ? diff ? management system ?
  7. please advise what is the standard weight of the flywheel on a 3t... will be skimming to lighten the flywheel to prevent the bolts from getting loose...how much must be skimmed 3.0 kg after skimming ....like i said using it for spinning.
  8. The bolts thread were hammer out but holes were fine the ring gear is quite heavy what can be done to lighten it ? can you send the size of the bolt pattern and length thread ? will check for high tensile bolts when using a torque wrench how tight should it be ?
  9. Hi guys, Does anyone had or know the solution to my problem on the crank gear So I'm running a 1.8 gl 3t motor stock with viper exhaust manifold only. Standard gear box. So this is what i am currently experiencing....was driving and doing some robot to robot racing and a spinning too...after doping that whist driving when changing gears whilst clutch pushed in Before changing i can feel from the pedal a vibration a sound also does this when driving at around 80/100MPH when leaving the accelerator that a rrrrr sound if I’m in neutral and Just rev high when the rpm drops that sound is evident. i was driving and suddenly no clutch anymore . I was thinking it was clutch gone.... dropped gear box and clutch was fine and pressure plate. The problem is on the ring gear the teeth look fine but its quite heavy weight is similar to the clutch or a just a bit heavier..the 6 bolts on the ring gear thread was worn out So at a nuts and bolts store but slight longer bolts with spring washer and locktite and re assembled and everything was 100% No sound everything soft and smooth....drove a bit rough again and spin just at one cornet not much and then that sound came back. Those bolts fitted are still new thinking Something is casing the ring gear to come loose what can it be ? crank gear crank not sure Another ring gear. I want to use the car for racing and spinning and want to ensure if I’m doing this the bolts on the ring gear holds ?
  10. will try that and see...if that works out.
  11. Hi guys. so my ride is back on the road. The problem was fixed had to drop motor. the crank gear was the problem was sitting in the gearbox and bolts were not tightened. Well bought new bolts and fitted everything back everything is 100%. just need to get a starter i am now push starting. The lucas starter replaced solenoid and bought bushes but tested on battery work but when i put the starter back not click on ignition completely dead ...could it be the armature or does it nead a clean up?
  12. Hi guys So my mechanic has done a check for me and his findings are. My starter needs replacing as its burnt out so the car does not start tried towing to start still doesnt he says my ring gear is turning and it should turn the fan whilst car off but if he turns ring gear its turning but fan is not. so he is saying i need to drop the motor to check? my motor could be gone is this true ?
  13. will be doing that ...what is the difference between 38 40 45 carb and best brand carb to get ? will the cortina v6 carbs work and will i get power ? weber and other brands ?
  14. what conversion and part will i need to convert my stock fan to electric and is this a big job to do ? I have a stock 3t motor 1.8 gl ....
  15. yeah buddie thanks...going that route making it difficult for these crooks Lol I love my ride. they like the toyota ke70 because its Rwd and spins just like E30 325is
