flat out
    944
Everything posted by flat out
  1. solved the problem, a little paint on the seal bit on the block, cleaned it up and put the filter on tight as, now it does's so f@$king hard
  2. some where around here
  3. ok guys, rebuilt my motor, got it running, once its ran for about a minute, it spits all the oil out, around the area of the oil filter, fuel pump, engine mount, blocking plate and oil pressure sensor, now I'm sure its not the headgasket, oil pressure sensor, i thaught it could have been the filter as i had a z9 on it, i changed to a z89a (recomended) the reason i thaught it could have been was because the z9 has an anti drain back, i asumed it might have flowed the oppersite way and pressured up, so could it be coming from the, fuel pump little blocking plate at the back of the block or the filter? one of the bolts is shonkey in the fuel pump but surly thats no reason for it to dump most of the oil at once? i really need help asap thanks guys
  4. pics of said 14x7 superlights, i run 13x8 allround 175 70 rear and 205 60 front, rears look sweet, sits inside the guards without my 25mm bolt ons :wink:
  5. the turbo is on ill take a picture when i get the chance
  6. cheers mate, thats what I'm going for :)
  7. got myself some goodies, also got a 10" thermo, it was $69 each or 2 for $85, so i brought 2 and sold one for $30 p[lut some 2t bits and old tyres a mate didnt want, had it running again but i put the wrong oil filter on and it dumped all its oil :) dad made the exhaust, only used 2 bends from an old 189sx exhaust, 3 inch all the way with one hotdog, verry pleased, cost about $160 all up, tell me what you think
  8. oh yeah thats shit hot, so I'm guessinbg you have all the other upright stuff :(
  9. needed urgent, ke55 ignition barrel, and rear brake hose (the long metal one that goes down the trans tunnel) asap thanks
  10. lost 3 points for suposibly running a red light, and a caution for not displaying p plates weird thing is they told me where i suposibly did it then wrote a different intersection on the fine, oh and dad backed my car into a trailer and mangled the roof
  11. pfft it doesnt do skids :)
  12. 65 ltr's gets me 375 km, buy that time the fuel light is on and I'm to scared to go beyond, thats about 6km to the litre it sits on 3000rpm doing 80kmh and about 400-4500 doing 110 when I'm naughty, this is a 3 speed auto 78 cressida, 2.6 ltr's of fury, very slow but spins 3rd in the wet haha hope the rolla gets the same or better
  13. what times your bed time? ill bring it around after tea
  14. yeah i have one leigh, no credit to reply lol
  15. 3t all the way, use ta22 engine mounts and it will bolt in nice and snug, nice and close to the fire wall. use a t18 diff as theres more options avalible, axles are easy to come buy, disk and lsd easily avalible, converting to hydro clutch is easy if you have a welder for the bracket off the pedal they have nice torque and are crossflow and you can turbo one cheaply and have good results my basic turbo 2t would fishy 2nd in the dry no worries. be warned i have never herda 2/3t sound nice
  16. give it a good cut with cutting compound then some colour restorer, can't go wrong, before the cressy is done none of the paint matches, when i do it its all perfect, 7 leaf rear with sierra shocks, ke70 struts with falcons in the front
  17. nichy! I'm a 13 year old girl from blackstone, give me your number :P
  18. with bells on get a list together, you can have fronskies in the coupe if you like
  19. can you stand and paddle yourself around in a canoe? good looking i must add
  20. ok, well it turns over, just taking it nice and easy to get every thing sorted, should be running in a week or 2 !
  21. yeah 13x8 all round with 25mm bolt ons on the rear, front tyres are 205/60 rears are 175/70 lol rims stick out a f@$kload on the rear
  22. decompressed internals, try and get hold of a t3 turbo and make an adapter, toyota turbo's are pox unless you want to spend a overrated and get a ct20b or ct15b more pics
  23. the black wheels are 13x8 superlights, unknown offset, changed from the meshies because there on my daily, howie is always stoned
  24. another update engine is in just need some gaskets and hose clamps and such till its ready to fire up. got some pictures of stuff
