Oldschool61
    9
Oldschool61 last won the day on April 19 2016
Oldschool61 had the most liked content!
  • Real Name
    Ronnie
Recent Profile Visitors
451561 profile views
Oldschool61's Achievements
  • Conversation Starter Rare
  • Week One Done Rare
  • One Month Later Rare
  • One Year In Rare
Recent Badges
  1. What is the proper valve lash and adjustment on a 83 toyota corolla AE71 4AC 1.6 engine ?
  2. Hey guys I'm looking for wiper arms for my 1983 LHD AE71 RWD WAGON . I've looked the internet over and can't seem to find nothing. I was wondering if the wiper arms from a later model Toyota Nissan Honda would work ? Any information would be appreciated.
  3. I have a 83 Corolla Wagon and was wondering if the lower control arms from a AE86 the same as the AE71 ?
  4. Okay your next step is to Heat the area around the plug area with a tourch , then strick the plug to shock it , then use a chisel and hammer striking on the plug to jar it loose . Remember the plug unscrews counterclockwise ! If you get that plug out discard it and replace with new one . Hope this helps
  5. If it were me I'd drain all the fluid by removing the lower drain plug , i think it takes a 17mm wrench to fit the drain plug . Remove the shifter from the tranny and the side filler plug whitch takes a 15/16 " or maybe a 22mm socket or wrench. After all the fluid has drained be sure to install the drain plug ! Fill through the shifter hole slowly until you see fluid coming out of the check/ filler plug .
  6. Hey guys I'm in the process of doing the same swap. Ive got everything for the swap except the clutch pedal and gearbox cross member. Where can i get these two items. Fozz , mentioned a T18 pedal box , who's got one for sell ? HELP !
  7. Hello . I'm in search of a 22 spline yoke for a T50 manual 1983 Corolla Wagon. Also looking for a complete rebuild kit for the T50 . Any help would be appreciated. Thanks .
  8. I've been told the SR5 pickup differentials are a direct bolt in, Other the the 5 lug bolt pattern . Hooe this helps .
  9. Hey guys I'm new here and can't wait to get in on all the info ! Thanks for excepting me ..
      • 1
      • Upvote
