normgale
    6
  • Real Name
    Norman Gale
normgale's Achievements
  1. Thanks Tojo2. I am concerned that there may be wiring issues that could cause me some grief so I am going to stick with another 4A-FE as a transplant or I may just consider changing the head because all this came about due to overheating; when they changed the belt and water pump the 2" long hose to the water pump wasn't tightened properly and she has continually leaked the coolant from there and now I am finding bubbles coming up the radiator.
  2. Thanks oldeskewltoy. I wonder what problems what the 10mm height difference would make as it sure would be good to get those extra KW's; my 4A-FE has cooling problems and would most likely cost more than a transplant.
  3. Thanks oldeskewltoy; I am just wondering what clearance I have on my AE101 to accomodate the extra height. I would love to put one in for the extra KW's as my 4A-FE has cooling problems and it would cost more to fix than the transplant.
  4. So will the 7A-FE fit easily or exactly into the same place as the 4A-FE?
  5. As an ex-airframe fitter in the RAAF, the solution to the potential differentation may be overcome by the use of a bonding strap connected to the radiator and then attached to the car body or where ever it is bolted to.
  6. Hi folks, just wondering how hard it is to put an 7A-FE into the place an 4A-FE will come out of? From all evidence, with information in the trusty Gregory's 271, they are exactly the same engine block etc.
