RustyKE70
    7
Everything posted by RustyKE70
  1. I've fitted everything on but I can't seem to make the drums fit, its like the shoes are sticking out too much.. >?
  2. Hi, thanks for the info. I still have to try cleaning out the contacts... I'm still unsure about how to but just taking a step at a time ^_^
  3. Hey guys, I was wondering if any one has advice on putting the fuse box back together again properly ? I have no idea what way they go and when i try theres a few still unable to plug in any where. http://i359.photobucket.com/albums/oo31/Erasmus_William_Macalister/20151002_1523591_zpstols6lyl.jpg http://i359.photobucket.com/albums/oo31/Erasmus_William_Macalister/20151002_1523381_zpsrtwx2e6h.jpg thanks.
  4. Does any one have a diagram of the fuse box area ? I'm trying to understand where it went wrong
  5. http://i359.photobucket.com/albums/oo31/Erasmus_William_Macalister/20150930_1615301_zpsctgc65nk.jpg Here I found what seems to be a earth just behind the steering wheel, It was loose! on one end but unfortunately no change occurred after tightening it I fear that what I've done to the fuse box next to the peddle has ʞ©$ɟed something else. http://i359.photobucket.com/albums/oo31/Erasmus_William_Macalister/20150930_1613551_zps6u46gghd.jpg http://i359.photobucket.com/albums/oo31/Erasmus_William_Macalister/20150930_1617492_zpspkcpfbyo.jpg This is the fuse box we replaced, there is a couple of connections that don't seem to have a home. Can any one make sense of this ?
  6. Thanks for the advice. There wasn't any maintenance on the vehicle at the time of the headlights failing but my driveway is very bumpy so I'm assuming thats the only cause or problems from water
  7. ke70 toyota corolla 1987 I've seen alot of topics on this issue but my issue is about reading the diagrams and wiring too the earth points? I can't understand them at all and I'm pretty sure its the earthing or the switchs around the steering wheel. So first the headlights stop working and we tested the loom and the bulbs and nothing seemed out of the ordinary then we took the fuse box out from besides the peddle and noticed it had water residue and had rusted a bit inside so we took it apart and cleaned it up. We plugged the fuse box back in and this is when every thing went A-wall, I decided it may have been the fuse box so i bought a new one but it had exactly same problems. All the threads I've been reading is 9/10 pointing towards bad earthing, i.e not being connected or old earthing having corrosion and needing cleaning. Now I'm a complete novice so these diagrams every one links make no sense to me, is there a basic map of the earthing in the car some where that I'm missing ? I know of the 1 from the Battery to the chassis but thats as far as i can see. Thanks.
