Seeno
    17
Everything posted by Seeno
  1. i have a 75 ke30 with a 3k-h motor all matching numbers and the number i have stamped in the spot you said is 19 not 39 not sure if this helps but thought i post it up anyways
  2. No leaks anywhere and i'm not losing fluid. I completely lost brakes tonight for a good 5 minutes, got home turned car off went and checked it about 5 minutes later and i had brakes again. I'll get a new master cylinder and new fluid, change them out and see how i go. Thanks for the help guys
  3. thanks for the help guys ill replace it and see how i go
  4. hey everyone i have a ke30 corolla and i think my brake booster is knackered. i still have brakes ( most of the time ) but every so often my pedal just goes to the floor. just wondering what brake booster ( off what model car ) people are running because you can't get thenm anymore ?
  5. cheers mate i thought that was all i needed but just wanted to make sure
  6. hey everyone I have a jap diff in my corolla just wondering what I have to do to put a borg warner diff in it as I can't find any japs diff? is it just the diff and tail shaft I have to replace ? j wanting to know cause I want to weld one up
  7. thanks mate
  8. hey just wondering how many people run lead additive in their fuel in a 3k motor and wether I should use it? my car runs fine without it but I know another person that does run it so I'm unsure
  9. .
  10. Too easy thanks
  11. I only want to get the motor going running right and keep it like that for a year or more and then upgrade to 4age or something. What price you thinking for that package taz rx
  12. Do you know where I can get another head or somewhere cheap to install new valves?
  13. #1, 150. #2, 25. #3 ,155. #4, 125
  14. cheers for the help guys turns out i do have a stuffed exhaust valve. does anyone know what pressure your meant to get in each cyclinder?
  15. ulvie on the northwest coast
  16. i've swapped the plugs and leads around the miss doesnt move from #2. I've also checked for oil in water and milky oil cap they are all good. no bubbling from the radiator either. the dizzy looks ok but it is hard to start in the morning but i live in tasmania so its pretty much frozen untill lunch time. ill check the compression soon ive also got a exhaust gasket ( 1 piece not toyota ) but if it might be a head gasket i might do it all at the same time. thanks for the advise mate
  17. Hey everyone I'm new to club and the whole ke corolla seen but ive just got a 1975 ke30 rolla with a 3k-h motor and i need help finding out whats wrong with the motor. The motor has a exhaust leak at the manifold, on idle it only runs on 3 cylinders (2nd from the front not firing) but when it's reving more it's firing on all 4. i have checked the spark and there is spark coming from the spark plugs but to me it doesnt look like much. Does anyone have any ideas what it could be ? Any help would be greatly appreciated
