Seeno
    17
  • Real Name
    Sean
Recent Profile Visitors
2483213 profile views
Seeno's Achievements
  1. i have a 75 ke30 with a 3k-h motor all matching numbers and the number i have stamped in the spot you said is 19 not 39 not sure if this helps but thought i post it up anyways
  2. No leaks anywhere and i'm not losing fluid. I completely lost brakes tonight for a good 5 minutes, got home turned car off went and checked it about 5 minutes later and i had brakes again. I'll get a new master cylinder and new fluid, change them out and see how i go. Thanks for the help guys
  3. thanks for the help guys ill replace it and see how i go
  4. hey everyone i have a ke30 corolla and i think my brake booster is knackered. i still have brakes ( most of the time ) but every so often my pedal just goes to the floor. just wondering what brake booster ( off what model car ) people are running because you can't get thenm anymore ?
  5. cheers mate i thought that was all i needed but just wanted to make sure
  6. hey everyone I have a jap diff in my corolla just wondering what I have to do to put a borg warner diff in it as I can't find any japs diff? is it just the diff and tail shaft I have to replace ? j wanting to know cause I want to weld one up
  7. thanks mate
  8. hey just wondering how many people run lead additive in their fuel in a 3k motor and wether I should use it? my car runs fine without it but I know another person that does run it so I'm unsure
  9. .
  10. Too easy thanks
  11. I only want to get the motor going running right and keep it like that for a year or more and then upgrade to 4age or something. What price you thinking for that package taz rx
  12. Do you know where I can get another head or somewhere cheap to install new valves?
  13. #1, 150. #2, 25. #3 ,155. #4, 125
  14. cheers for the help guys turns out i do have a stuffed exhaust valve. does anyone know what pressure your meant to get in each cyclinder?
  15. ulvie on the northwest coast
