Dudematters
    6
Everything posted by Dudematters
  1. Found the backlights, was the connector of the light switch, didn't remove that one during the rebuild, but still it makes bad connections. All is working now except for the head - lights left and right, can't find them yet.
  2. I don't have any power on the connector (near the light in the hood).... if I turn on the light switch I should have 12v there...
  3. Don't the lights have earth on the body?
  4. I have a strange issue... after restoration most of my lights are not working. The light under the bumper front (indicator & city light) works. The indicators left work and blink The reverse lights work The brake lights work The high - beam lights work when operated on the indicator swich (for passing) The indicators right work (side and back, but not under the front bumper) but do not blink The headlights do not work (normal & high beam) The light under the front bumper (right) does not work The tail lights do not work. I've checked the light switch, that works. I've checked the fuses, they all seem ok. I've checked the wiring, seems ok, but have no power on them when I switch on the lights... What am I missing?
  5. Thanks Lou, I'll definitely look into Phil's Rotary... Here's some more photo's of my progress.... - In search of shock absorbers that will fit in the factory setup... like to buy them locally in Malta if possible...
  6. Hi, Just wanted to show you my KE10, it's in Malta (EU) and is a 4-door version. I own the car for 3 years now and currently respraying it. When I bought the KE10 it was in reasonable condition but sprayed 3-4 times over the original paint, causing some strange effects over the years. I am the second owner of the car.
