1975 KE30
    14
  • Real Name
    Dylan
1975 KE30's Achievements
  1. Hey guys was wondering what the most reliable and Has better performance 4age to go into my ke30 and also what other components I'll need (tailshaft, diff) and also is a t50 box suitable for this application thank you
  2. Hey guys was wondering if there's anyway of getting camber on the stock front struts on a ke30 if not what's the easiest way to do so (easy clilover install) thanks
  3. And what's that
  4. Would it be an easy conversion, straight bolt up because it's the same car
  5. Hey guys I just bought a ae92 with a 4afc carby motor in it and was wondering if there is any cheap mods I can do that will increase power a bit, and would it be possible to swap the carby with efi Ps I don't have the money to put a 4age in it
  6. This is probably a dumb question, but would a stock diff and tail shaft work with a 12a/13b ??
  7. Apparently the 13b won't be legal in a ke30 but a 12a is or is that wrong Ideally I would like to have it as a street car in nsw
  8. Hey guys I was looking to see if anyone has done a 12a swap in a ke30 If so -how difficult -the hardest part -what gearbox, tail shaft, diff and front end -rough cost -what modifications needed to be done Thanks
  9. Car: 1975 KE30 4 door sedan Modified/Unmodified: 50mm lowering blocks in rear, stock height front Rim Size: 15x8 Rim Offset:+-0 Stud/Bolt Pattern:4x114.3 Tyre Size/Profile: 195/50 r15 stretched Fitment Note: Sat really nice in the rear with shaved guards and stretched tyres, didn't scrub after guards were shaved, however the front stuck outside of the guards by about half an inch to an inch
  10. Just wondering if there were any KE30's that were stock air con, if so would it be difficult to install an a/c unit
  11. Hey everyone I've got a really odd question here, I've got a 1975 Ke30 and was wondering how the heater function works (like defrosting front window etc.)
  12. Thanks that helped heaps
  13. Hi everyone, I've just recently bought a 1975 KE30 with a 4k engine instead of the original 3k-h engine. I was wondering if anyone knows what the stock hp is on a 4k please.
