frosty
    163
Everything posted by frosty
  1. tool, it is not our problem that when you were at school and they were teaching english; you were too busy up at the back of the class playing with yourself to bother to learn how to spell correctly. It is up to you to fit in with us. If you need to find someone who can read it out aloud to you, then let us know.
  2. So.... that will be a kit for your pushbike or your billycart?
  3. Like the others I always go to 'view new content' and would prefer that things stay as they are. as an example (in my instance) if I click "new content" I get 14 odd posts since I was last on .. = win. :y: However If I click "Active" content" then I get 80 odd posts ( from the last 24 hours) = BIG PIA as your going through stuff that you have already seen. :bash: that's my tuppence worth :yes:
  4. Fantastic :dance: keep up the excellent work :y:
  5. probably because we can't get to read the Wagga fish and chip wrappers are you a 6 year old ??
  6. $5000 :lolcry: for a Ute and it's not even restored !!! thanks
  7. Where abouts is the morris located? - at a wreckers or in a shed somewhere?? cheers
  8. Impossible for all pots to show the same figure. You want the figures for each individual - 1,2,3,4. cylinder. Also was the test done wet or dry?
  9. Thanks guys
  10. Has anyone on here bought and used one of these ?? What was the quality like any problems with it after instalation? http://www.ebay.com.au/itm/3-core-aluminum-alloy-radiator-toyota-Corolla-AE71-AE72-/300585265574?pt=AU_Car_Parts_Accessories&hash=item45fc4729a6 Will be going infront of bigport 16V cheers
  11. Thanks heaps fellas, time to find some pipeing etc and have a bit of a play and see what comes of it.
  12. Thanks Currently with mate in Melbourne Exhaust is 50mm dia from the manifold back. Standard Toyota 4K carb with 5k jetting and no pollution gear Inlet manifold is standard 3K Interesting, even in Port Macquarie, the first 15 mins or so were a cough and splutter affair until she got some revs going and some general heat in the engine bay while the top daytime temp has been about 12 or 13 degrees it is no better. :bash:
  13. Normal system - probably about an inch 1/4 Why the questions on exhaust size?? - what effect is that going to do to the throttle response??
  14. Do you know if any of the 4K or 5K motors have water heated inlet manifolds? I have fitted extractors onto an old 3K manifold and it needs some heat under the inlet box. I wonder if water heating the manifold would reduce a lot of the hesitation on trying to accelerate from very low revs because of speed humps, roundabouts, any other place where you have been on a trailing throttle for a while. Thoughts and ideas ? cheers
  15. More than likely it's a 3 rib bigport therefore no squirters. Great little engine - :yes:
  16. Great Kent ... I'll grab them if you don't want them -- what else you got?? cheers frosty
  17. Thanks mate - found some part numbers - cheers :y:
  18. Does anyone know for sure if you can buy the castellated nut and special lock washer that fit on KE70 axel. can't ring toyota as its Saturday !! Does anyone have a parts list at all with these items in it? thanks frosty
  19. frosty
    New Laws
    http://www.sper.qld.gov.au/ls_faq.htm
  20. Here's a start http://www.rollaclub.com/faq/index.php?title=File:1974onKE30WiringDiagram.jpg
  21. OK thanks - I take it that the towers are different heights??
  22. Hi Guys Are 55 and 70 engine mounts the same? ie interchangeable?? thanks
  23. Altezzaclub- thanks
