frosty
    163
Everything posted by frosty
  1. You can check here, any wheel size you lik https://www.wheel-size.com/
  2. I hope that this is what you are looking for 7K PDF manual https://drive.google.com/file/d/1wEmuOrLHUnWZSuMEeOsNvOHm4_mH0QaN/view?usp=sharing
  3. cheers for the reply Banjo ~ I had had a search to no avail. I knew about replacing the whole strut, but my question was really about wether the ST141 corona brakes - backing plate, rotor and caliper ~ would actually just bolt to the existing strut.
  4. Would anyone know if you could bolt up ST141 Corona brakes to the ke70/55 strut to achieve 250mm discs? thanks
  5. Hi, currently chasing a ke55 booster but having trouble sourcing one. I have found a AE71 booster interstate, so unable to trial fit to see if it fits. Does anyone know if it will, or what other booster will fit the pedal box. Will buy a 55 booster if someone on here is selling Using ke55/70 discs (on a project non corolla car) cheers frosty
  6. OK, thanks for the idea, will see how that goes.
  7. It went from reverse to first and then stuck there Can move the gearstick as if it is in a mixing bowl. Could of the ball on the bottom of the gear stick broken off - is that even possible.?? Havent looked at anything yet as car is about 100 k's from home when it broke down.
  8. seems to be jammed solid
  9. Has anyone had this happen and the likely cause and a remedy" ke70 5 speed locked/jammed (immovable) in first gear new box or fixable? I have no idea lol
  10. I have had machined up (years ago) a ke55/70 front stub axle and pressed into my project car. This was so I could just use a complete 55/70 front btake, running 14" rims. I am now going to use 15" steelies. My question is, does anyone know what larger brake unit fits the ke70 axle - ie: same size bearing etc, so that it will slip straight on as the smaller one would. thanks
  11. Banjo - 7K manual added
  12. Try here ~ https://drive.google.com/file/d/14P1j8GZ7udpCkTSQ5bCyOs3EysRu0r26/view?usp=sharing
  13. here you go mate ~ HERE
  14. in the glovebox out of the way cos you don't need to use a phone whilst driving
  15. https://www.academia.edu/7407534/Toyota_Engine_7K_Repair_Manual
  16. thanks for getting it back online
  17. 1350 sounds about right as ta22 is 1355 drum to drum
  18. Here ya go young fella https://drive.google.com/file/d/0B-Yb6y6qxw1gdkt3dnQ2SFVkQzQ/view
  19. easy search ..... http://www.rollaclub.com/board/topic/5644-4age-into-ke70-ae71-conversion-the-step-by-step-noob-guide/
  20. https://www.google.com.au/?gfe_rd=cr&ei=1-78VvD_MczN8gfqrrbIDA&gws_rd=ssl#q=diff+ratios+KE20
  21. :thumbsup: Thank you - a great informative and easy to follow read. Tags on the photos help as well. ... my favourite was the repurposing of the window slides :2thumbs: well done !
  22. Is this of any help ? http://files.aeu86.org/manuals/4age-diagnosis_manual-parrot.pdf cheers
  23. Just uploading file now ~ will PM link to you cheers
