ke30kb
    10
Everything posted by ke30kb
  1. Hey guys, I've just purchased a Ke30 in the original mustard. I would like to give it a respray in this colour. I'm struggling to find the paint code anywhere. If someone could provide that to me, I'd appreciate it.
  2. That's for the help guys, it did help. Made me pay attention to certain areas. It ended up being that the dimmer switch connection was cactus. Once replacing that, the lights came on. Did a voltmeter check and found it had no power to it!
  3. Hey Banjo, You're 100% right, thank you for your feedback! All other lights are working as you've said. It has to be the dash earth! I've been searching high and low and still can't locate the bloody thing! Going to have another thorough look tonight!
  4. Hey guys I have recently out my dash back into my 76 Ke30 sedan, I noticed that I haven't relocated my dash earth and have no idea where it is so as you've guessed all my accessorie lights are out! Where can I find the dash earth so I can get my lights working again?
  5. Hey guys, just noticed after installing my dash my acceptors lights aren't working either. Aircon back lights all dash lights are not functioning. Have replaced all fuses. Starting to really puzzle me
  6. Yeah man one of the first things I checked, I'm going to replace all of my fuses fingers crossed
  7. Hi Banjo, Thank you for your response, I actually haven't changed the globes at all however, swappedthem with the working ones to see If they were blown. Is there a fuse for them?
  8. Just got my dash back from getting re-vinlyed, I installed the clusters. - Speed, Petrol and Heat signal active - Park brake light and indicators lights active - Speed backlight and the backlight for the petrol are out? All the connections are in the back correctly, what could be wrong?
  9. I'm looking for the RPM signal wire in my 76 Ke30 to install my RPM Tacho, I haven't had any luck and was wondering if someone could help me out in locating this wire. I'd greatly appreciate it. I've got all the other wires sorted Cheers guys!
  10. Hey Guys, I currently have a 1976 Ke30 Corolla with a 4K, I'm wanting to spend a little bit of money but not too much to get some more power to it. If someone could give me an idea of a starting point as I have no idea where I should even begin that would be great. Maybe even if someone lists everything I should do that's worth it, I'd greatly appreciate it. Cheers.
