cool_rolla
    10
Everything posted by cool_rolla
  1. Hi @altezzaclub, First of all, thank you for the awesome reply! Ill head to the garage and check everything base on your comments :D. Best regards!
  2. Hi Guys, I'm having trouble with my ae92. Everytime I hit the road potholes or ditch road I heard clunking noise and I feel it was came under the steering wheel. I'm not sure if its the U joint or whatever.. Please help me guys where can I found the root cause. :( Best regards!
  3. I decided to replaced it because I just want it to be easier to clean compared to original one :). I made a few adjustments for the air jet as well because I feel that the air is too much? @LittleRedSpirit Yup! Oil Catch Can is next to the line.. I just have to modify first the air filter housing to attached the thermal valve thing. Ill keep you all posted :) Thanks a lot!
  4. Hi, I replaced the air filter with this one image attached. Now, there is no other way to attached the thermal valve thingy otherwise I could make a hole to the air filter housing to fit in to it though I'm not sure if its going to work. Is there a way to test if this thermal valve thing still working? I'm trying to suck/blow the pipe if air is coming out (me looking stupid :P). Last thing, Is it safe if I temporarily plugged off the thermal valve thingy? Best regards,
  5. HI @altezzaclub! I replaced the entire air filter assembly. Here's the pictures of my old air filter housing or case (not sure the name of it. LOL). See attached. Best regards,
  6. by the way, that image was attached from my old air filter and there's hose connected to it.
  7. Hi Guys! I'm about to replace my air filter and the filter that I've just bought does not have a place for this thingy (please see attached image). I wonder what is that thing for and is it ok if could just close that thing off? Best regards!
  8. Hi Guys! (me feeling excited) I just replaced the pcv valve and yup it has to be replaced. I bought a replacement and so far it seems ok and the other pipe is now sucking the air. Now I have to wait if oil still persist from the air filter. I also bought a carb cleaner and sprayed on the fuel vent and almost part of the carburettor. :) Thank so much guys for helping me out! Cheers!
  9. @LittleRedSpirit it's been 200k km already. Today I'm about to examine the pcv valve and if it needs a replacement. By the way, do I need to remove the valve cover for me to take off the pcv valve? Another thing, it has air coming out with this other pipe is that ok? I'm very thankful that you guys exists! Thanks a lot for all the replies. :)
  10. Hi everyone! I'm having hard time figuring out why there's oil on my air filter. By the way, spare me I'm newbie and I am very thankful if you guys could help me out.. Here's what I'm up to: I haven't checked the pcv valve yet though I'm not sure if this related to the problem and I feel that the oil came from the other pipe of the crankcase cover. I don't know this other pipe called and how it works (please see attached)? Best Regards, Zandy
