focus218
    30
About focus218
  • Birthday 08/21/1986
  • Location
    CYPRUS
  • Real Name
    Michalis
Recent Profile Visitors
5049546 profile views
focus218's Achievements
  • Reacting Well Rare
  • First Post Rare
  • Collaborator Rare
  • Conversation Starter Rare
  • Week One Done Rare
Recent Badges
  1. Thank you. Will do the connections tonight and update the results.
  2. Hey Banjo thanks for the reply, The main issue I have is that I don't know how to do the wiring with the new alternator. I have been having some issues with my old one which is a 30A that came originaly with the 2K engine. So, I found this used 40A, took it to a pro and had it tested and also had the brushes changed, just in case. Now, I have no idea how to do the connections.
  3. I know its simple but I couldn't find any info online. The first one is from my 2K engine and the second is an "upgade" from a 4K. Which wire goes where? The old alternator was with a 3 pine fuse and one lose wire connected on "B" screw while the new is just with the 4 screws. Help please.
  4. Sorry for the late reply.
    Yes it is still for sale.
    Make me an offer I can not refuss.
    Please send reply to
    [email protected]
    Cheers.
  5. I noticed that there are a lot of Rear Louvres sold in Australia's Gumtree site and was wandering if any other car has the same dimensions as a KE70 that will fit right on without any modifications. Any help is welcome.
  6. Ok guys, I know it's useless for some of us, but I was just going through old posts and noticed that some numbers are controversial between us. After checking my Toyota K Repair Manual I need some final factory recommended numbers missing: 1. WATER TEMPERATURE 2. WATER PRESSURE 3. WATER THERMOSTAT OPENING TEMPERATURE 4. OIL TEMPERATURE 5. OIL PRESSURE 6. FUEL PRESSURE 7. FUEL OCTANE
  7. Thank you altezzaclub for the file . This will be very helpful finishing the wife's KE70 project. I wont be needing the USA market one because I'm in Europe. I will need though the KP30 or KP36 one because I am rewiring mine and I will be doing it factory style.
  8. Been searching the web and can't find anything. Any help is welcomed.
  9. Try this site.https://www.willtheyfit.com/ Pretty sure they will fit.
  10. ***FIXED UPDATE*** I have to say that I finally found and fixed the issue. The mains where too small making the engine running lean. What I used : primary main jet = 125, aircorrector = 180, emulsion tube = F50, idle jet = 55 secondary main = 130, aircorrector = 195, emulsion tube = F6, idle jet = 50 What should be used in a stock 4K engine with a Weber DGV 32/36 primary main jet = 140, aircorrector = 180, emulsion tube = F50, idle jet = 55 secondary main = 135, aircorrector = 195, emulsion tube = F6(under no circumstances do not use F66), idle jet = 50 Works like a charm. Many thanks to altezzaclub and davew7 These two sources also helped a lot: https://ratsun.net/topic/2125-weber-carb-hesitation/ http://www.3fowlers.com/Weber Trouble Shooting Guide.pdf
  11. Hello from Cyprus. Ok guys I really need your help re-jetting my Weber 32/36. I' ve searched the entire internet and can't seem to find a straight answer. I have a stock 4K engine on a KP36 Ute. Bought the engine brand new from an old part store, doesn't even have serial numbers on it :) These are the following installed so far: Stock 4k motor Weber 32/36 manual choke 4 X NGK BPR5EY Spark Plugs AccuSpark Electronic Ignition AccuSpark 12V Red Coil Custom Extractors 4K Heavy Duty Water Pump 71 Degrees Celsius Low Temp Stainless Racing Thermostat Racing Mechanical Fuel Pump I recently followed the advice from an old post in another site and tried re-jetting it with the following: primary main jet = 125, aircorrector = 180, emulsion tube = F50, idle jet = 55 secondary main = 130, aircorrector = 195, emulsion tube = F6, idle jet = 50 The car drives like SHIT. This is my everyday car. I start it up at 5am and needs 10min to warm up. I pull the choke and it shuts off. As soon as I start driving it just hesitates. It's driving me mad. I even bought an electronic distributor and brand new coil and sparks. What are the best Jet Sizes I can use? You are my last hope.
  12. Hey guys, I was just wandering if anyone has a solution for the cheap made rear tail lights for the KE70. I bought a few months back a pair from ebay and now the colors have faded out. https://www.ebay.com/itm/TOYOTA-COROLLA-KE70-E70-TE72-1979-80-81-REAR-TAIL-LIGHTS-LAMP/132739016963?hash=item1ee7dca903:g:cRQAAOSw8GtZWPeW:rk:13:pf:0 https://www.ebay.com/itm/PAIR-TOYOTA-COROLLA-E70-KE70-TE71-REAR-TAIL-LIGHT-HOUSING-LAMPS-RH-LH-1980-1981/123009582810?hash=item1ca3f146da:g:S6AAAOSwSB1aoXXo:rk:23:pf:0&LH_ItemCondition=3 Is there a way I keep the bright original color?
  13. Hey Tim, try these out. Don't know the exact size but hope it helps. https://www.ebay.co.uk/itm/4STAINLESS-STEEL-BOLTS-SCREWS-CHROME-BUMPER-FITFOR-COROLLA-KE70-TE71-TE72/150941809301?hash=item2324d53a95:g:DzoAAOSwcwhVMPU~:rk:11:pf:0 https://www.ebay.com/itm/371355132305 Cheers
  14. I am not familiar with how many diffs there are out there, if I were to buy this one which seems to be the only one available, would it fit? https://www.ebay.co.uk/itm/Toyota-corolla-AE86-t18-4age-m-t-T-series-diff-gears-3-7-ratio/263714728652
