balaiz
    91
Everything posted by balaiz
  1. can't find where to buy a serpentine belt for a 2tc. mine is cracked. can anybody suggest any shops? I'm not even sure if its called a serpentine belt too, the one I'm looking for is connected to the water pump and front fan. sorry new to these engines.
  2. might have to pull the front fenders how do i know how much backspacing the wheel has?
  3. can i fit in a set of 15x8 with 0 offset wheels on a ke30. might put a 195 or a 205/55/15 tires. looking at getting a set of rota rkr 15
  4. got the valve to come loose just need the money for the push rods thanks alot bro
  5. wont the valve fall off if i do that? ill search for some spring compressor without removing the head any idea what its called?
  6. car hasnt run in 5 years, i just bought it for 600 i don't think the valve stem is bent cause it looks straight to me I'm thinking its stuck on the vavle seat. how do u remove the head? didnt see any bolts anywhere lol also if i take off the head i need new headbolts right?
  7. its stuck bro i straighten the pushrod as best as i could, then put it back and the rod is bent again, stuck valve. what can i do to unstuck it?
  8. i think ill order on brdracing they seem legit lol will do that later ill let u know what happen thanks
  9. what does a charcoal canister actually do? i think mine's clogged. not actually sure but theres many hoses lol one hose goes to the other side of the engine bay -.- when i bought the car it already had a 2tc and its a ke30 corolla
  10. i live in north america lol will that one fit without any problems? i thinkg its stuck closed lol not sure on how to test it
  11. also how do i test if the valve is not stuck
  12. where to get push rods for a 2tc? my intake rod is bent
  13. sorting out my vacuum lines and i don't even know what this thing does or what it is first working on carbs
  14. did it work?
  15. didnt eben know it was that cheap lol thanks would prolly buy a new one
  16. my rear right brake cylinder is leaking and i need to pass a safety inspection in canada. what cars has the same brake cylinders as mine? as i can't afford a new one, just lost my job T.T
