allpr0h
    9
Everything posted by allpr0h
  1. that was my main question... i can't imagine it can't be replaced, however is to know what are the dimensions of the bearing in question oh oh oh
  2. hi folks i have a 1997 corolla with a tein suspension, coilovers, with pillow ball top plates. my top plates are worn out, my question is can i use stock strut top mounts with my tein coilovers???//.. until i send them to tein for a rebuild thanks a lot nate
  3. wtf did i just wrote there sorry, i mean clean the ground connections of the ignition system maybe make sure the distributor cable shield connection to ground is neat
  4. yar your gauge is probably off.. i think if you clean all ground connections on the black/orange cable, the one that feeds injectors and coils, you may get better reading... just a thought
  5. you sure of the specs of the engine mate? me i used to think all the time that my 4efte would rev up to 7200 max, but now ive read rumours that it may rev up to jeez 7500rpm so now its got me wonder.. i don't get why the rev limiter would not be there it must be secured electronics if engine runs good then i guess computer knows what rpm its running.. very strange to me that it would let it this happen are you using an aftermarket rpm gauge?
  6. cool thanks
  7. hi folks i have a dead big port t-vis 4age and a small port non t-vis red top swapped in. should i take the cams out from the big port as i can read they are more agressive... is this gonna be positive? thanks nate
