Aussie_KE70
Regular Member-
57 -
Real Name
Luke
Aussie_KE70's Achievements
Wow, thats alot of caliper clearance...
Have you made a move on the side mount of Gumtree??
Reed, also have a look around for an ARC side mount for an R32 / R33 they are meant to be 100mm thick I believe. Every now and then they pop up and people are always giving them away cause the price of a china front mount makes them nearly worthless
Series 1 C34 Stagea (RB25DET Series 2 from and R33 GTST) Series 2 C34 Stagea - These vehicles particularly the WGC34 have an R34 GT-T engine RB25DET NEO and drive train with S14/15 front and rear steering and suspension C34 Stagea 260RS (R33 RB26DETT, altessa 4wd etc etc) These run a front mount intercooler just like the GTR's The stages's vins the key to knowing what they have as per the below chart Chassis Code Model Name Engine Size Drivetrain E-WGC34 X AERO SELECTION 2500 2WD E-WGC34 X 2500 2WD E-WGC34 RS AERO SELECTION 2500 2WD E-WGC34 RS 2500 2WD E-WGC34 G 2500 2WD GF-WHC34 X 2000 2WD GF-WHC34 G 2000 2WD E-WGNC34 X FOUR AERO 2500T 4WD E-WGNC34 X FOUR 2500T 4WD E-WGNC34 RS FOUR V AERO 2500T 4WD E-WGNC34 RS FOUR V 2500T 4WD E-WGNC34 RS FOUR AERO 2500T 4WD E-WGNC34 RS FOUR 2500T 4WD E-WGNC34 X FOUR AERO 2500 4WD E-WGNC34 X FOUR 2500 4WD E-WGNC34 RS FOUR 2500 4WD E-WGNC34 G FOUR 2500 4WD E-WGNC34 260RS Autech Version 2600 4WD
It depends if it a Series 1 C34, they have the head lights and driving lights in the one light assembly made from 1996- late 1998 the Series 2 C34 has the head light separate from the driving lights/ high beam and they are located in the grill. I have a Series 2 C34 Stagea dayz edition. It has from the factory a 80mm side mount intercooler.
look for a C34 Stagea cooler, they are the same as the R34 items
Any update :wootjump: :wootjump: :groupwave:
What is the colour?, by the way the car look fantastic. Excellent job
take a fridge magnet with you mate and check the seals for bog.
Ke70 Standard/ Stock Asian Carby Help
Aussie_KE70 replied to Aussie_KE70's topic in KExx Corolla Discussion
I have cleaned all that last night. The carby stripped down soaked in fuel for 24 hrs then I cleaned it with carby clean and compressed air. I paid particular attention to the idle circuit, jets and venturies of the carb. The engine manual specifically mentions that if the idle mixture screw is damaged by being screwed to far in against the seat, ie creating a circular impression on the taper that it is to be replaced. -
Well it turns out that I can get a new mixture screw for the carby for a hefty $27 from bursons. I'll have a brand new item in my hands on monday -
I reccon I will use some 1000 grit wet n dry and re profile it as the marks would only be just deep enough to catch your finger nail, but I do remember it having a ridicules high idle before this started. At this stage the idle in gear would be around 800rpm with the hand choke pulled out around 1/4. Cheers thanks for your help. I'll give an update in a couple of days after the weekend. -
Do you think it is possible to re-profile the screw?? -
To be honest it is 100% better than what it was 2 days ago BUT at idle it will stalls when putting it into gear, the only way that I can get it to hold idle in gear is with the hand choke. I am attribute this directly to the AFR's being too lean. If that's what it has to be, well so be it but I would like to get it to idle in gear with out the choke. I don't suppose you know where I could located another mixture screw?? I have checked the local wreckers here in Gippy with no luck -
Okay so last night at 12am I had the carby back together and on the car, first hit of the key and it fired and ran on the hand choke. So I adjusted the base rpm screw took the hand choke off and it began to idle....... bonus..... BUT at idle ie 750-1000 rpm it has developed a slight miss, but under load, ie put it in gear (its an auto) and with the hand brake and foot brake on and pull the choke out to increase the rpm, it idles without a miss. So I attached my wide band O2 sensor to the exhaust to see what the mixture was and I attached the vacuum gauge to the carby. Now the vacuum is sitting at 30 inches of mercury (please ignore my ignorance but is that normal or low????) And the AFR was sitting at 18.7 which is about 0.5% CO emission at around 900rpm which is really lean, now I tried to adjust the mixture screw and it made 0 difference. I have checked the timing again - its sitting at 8 degrees at 900rpm, valve clearance are correct and I have not found any vacuum leaks (checked with a few sprays of "start ya bastard"). My questions are; 1) 30 in Mg is this in the normal range for these engines ? (I know that there are many variables that effect this) 2) Is the AFR sitting at 18.7 normal? given that 1% of Carbon Dioxide is usually only recorded between 14.7 and 15.2 AFR (Engine manual states to tune idle to 1% CO reading at 750 - 800 rpm) 3) In my experience a miss at idle with no load indicates a vacuum leak but it also could be an incomplete combustion due to the lean AFR? thoughts
