van_kool1
Members-
22 -
About van_kool1
- Birthday 09/11/1994
Location
Perth, WA
Real Name
Braiden
van_kool1's Achievements
I'm the same, day cruise sounds better, work takes up too much time
Converting 4K-C To Electronic Distributor
van_kool1 replied to van_kool1's topic in General Mechanical
Have you cranked it over yet? I'm in Bali at the moment, any thoughts on trying to find an electronic dizzy? -
ands its a bosch distributor, so will the hot spark work? will i need to put a nippondenso dizzy in and then convert it? Thanks -
thanks for your response, but is it vacuum-advance? -
Its an Auto at the moment but will be converting to manual shortly, if that makes a difference -
Or would it be easier instead of using the MSD 6AL to just use the Bosch Ignition module with the blaster Coil? -
Hey guys, I've been looking around through a few threads and can't quite seem to find the answer I'm Looking for. What I want to do is convert my points ignition to an electronic one, however, in preparation for a future engine build I'm looking at doing it with MSD gear. What I'm looking at are these; http://www.msdignition.com/Products/Coils/Stock_Replacement/8203_-_Blaster_2_Coil_w/Ballast___Hardware.aspx http://www.msdignition.com/Products/Ignitions/Daily_Driver/6425_-_Digital_6AL_Ignition_Control.aspx http://www.ebay.com.au/itm/toyota-3k-4k-5k-corolla-electronic-distributor-ke10-ke20-ke30-ke55-ke70-ke38-k-/111272845830 The car has a Bosch Distributor and changing the points often is giving me the S@#$&, as the car starts to run rough. Looking through jackbyo's write up (http://www.rollaclub.com/board/topic/46089-how-to-install-an-electronic-distributor/) will the same instructions still apply with the gear I'm looking at? And Is there anything I'm overlooking? Excuse the noobness, I was working on EFI dunnydores before making the switch. Cheers in advance
I found the event On gumtree, so I'm not the organiser, but I hadn't heard of them, so I'll give them a like, maybe they'll know more
Alright Perth RollaClub we need a better show up of Cars, Toyotas in the park was great yesterday, but I reckon we should get together more often and on the entry form for titp next year have that we represent RollaClub WA. How about we drag the cars out for a Car Cruise? http://www.gumtree.com.au/s-ad/scarborough/activities-hobbies/oldschool-jap-cruise-03-11-13/1028596635 Meet at Scarborough Beach Car Park at 10:30 on November 3rd. Hope to see you guys all there. Perhaps we could get some stickers or something made up so we actually look like a group aha
yeah loved the little rollas that showed up, that little one with the 2tg was sweet as
- 6 replies
- Park
- toyotas in the park
(and 8 more)
Tagged with:
Who's going to Toyotas in the park this year? http://www.teccwa.com/entry
- 6 replies
- Park
(and 8 more)
Tagged with:
Let it be known for future readers of this thread, home brand superglue is perfectly fine for fixing your choke knob with... No need with a name brand the cheap crap works just fine
- 21 replies
- KE70Engine
- conversion
(and 3 more)
Tagged with:
Yeah thanks for that, I see there is a spot for some sort of screw or something, but I tried the old araldite and that didn't seem to last one pull on the knob... Cheers
- 21 replies
- KE70Engine
- conversion
(and 3 more)
Tagged with:
Yeah well the idea only popped into my head because I found a 2jz On gumtree for $400, so rebuild was the idea... But a 4k would probably be better, stick original and be different by keeping the original motor aha, already has 8" deep dishes On her so rins are set, suspension would probably be next then... While I'm here, anyone got any tips on sticking that black bit back on the choke? I have to pull the choke with pliers on the cold mornings otherwise... Thanks
- 21 replies
- KE70Engine
- conversion
(and 3 more)
Tagged with:
Aha cheers for the help guys, maybe I'll just buy a second hand 4k and build it up, then I'll only change the engine number and hopefully make it a manual, until I'm rich or win lotto, thanks for all your help
- 21 replies
- KE70Engine
- conversion
(and 3 more)
Tagged with:
