pizzafever1
    9
Everything posted by pizzafever1
  1. thankyou kind regards
  2. Do the 4age turbo manifolds that are all over ebay / internet bolt onto the 7afe Do they share the same bolt / header pattern
  3. Hey guys I'm confirming Just fitted a101 strut bar direct bolt onto to ae112r sportivo turbo rear top struts Just need to chop away a tad on the surrounding plastic speaker covers
  4. Hey guys.theses are super expensive quoted $ 12,000 by toyota spare parts I'm guessing these are old backup stock as they wer special build at the time I have a contact In japan who can precisley replicate the oem turbo sportivo ecu with warranty & guarantee special order tho itl cost 2000 $ also note some capictors on the oem ecu are of low quality n burst which is probably why yours blew up n a few other guys have too.
  5. Impossible to find any specs or info on the turbo engines. Basically most the parts are slapped onto the non turbo block. the turbo just use the IHI part & spec numbers and find something to match . How many kms on the car when the turbo failed. By memory they used a little ball bearing type turbo .? Where abouts are you located. willing to help .
  6. OK guys, apparently its a very common issue with AE112 corolla running the 7AFE whether its turbo or not. The Dizzy itself are very well known for FAILING sometimes. when it does usually it cuts the ignition. These dizzys are large and also have a intergrated COIL inside of it . If you ever have cutting out issues. Just replace the dizzy !
  7. hey guys as topic asks does the ae101 rear strut brace (2 point ) from the top strut bolts, on the ae112r corolla. ( sportivo turbo )
  8. very strange
  9. Easy Fixed , check loose dizzy connector working fine now . cheers
