Corbo.1432
    10
  • Real Name
    Corey
Corbo.1432's Achievements
  1. where would i find them, I'm new to corollas?
  2. thanks your your help mate
  3. To be honest think it might be 4age time
  4. alright thanks mate, so can i fix the oil in the spark plugs or not? also will the earth from the gearbox some how effect the starting of it
  5. I'm pretty sure i got everything, where would the earth be?
  6. Hey guys i just changed my clutch in my ke70 and now the thing wont start, it cranks and keeps cranking but nothing at all, its getting fuel to the carby i can see that, there is oil in the spark plug well number 3 but i took the first spark plug out and tried to see if it was sparking but didnt seam to be, any ideas what this could be, and why is there oil in the spark plug wells
  7. so today my car started to loose power and only rev when in gears, now it doesnt go anywhere when its in gear it is like its in nutural, no gears work not even reverse, clutch cable is fine, any possibilities?
  8. Update guys, got it idling fiddled around with the screws on the carby, when the choke iin it doesnt idle at all, when its out it idles but very very high, don't have a tacho but up around the 4000rpms id imagine, fiddled with the screws on the carby trying to balance it and get it right but no luck?
  9. Thanks guys, also dave its just i don't have the cash to throw parts at it to find out its blown, the car seams to idle once i pump the peddle abit when its off, runs for about 10 seconds with no acceleration, tried to sorce out the tractor sound and it seams to be coming from around the exhaust manifold area
  10. Hey guys I'm new here i have been having a problem with my ke70 and its stock 4k, the car will not idle at all even when in neutral to keep it running i have to keep revving it, also when i take off it has no power what so ever barley gets up to 60kms the prevous own told me the manifold gasket needed replacing, makes sense because it sounds like a tractor. What would be the causes of no idle and no power but, could it be a blown engine? no smoke coming out or anything The car is also manual Help is really appreciated thanks :)
