BOAT ANCHER
    32
Everything posted by BOAT ANCHER
  1. :) all good i got the gearbox now motor check gearbox check bell housing check diff ?????? don't have a dif yet not shore what to run can u put disc rear end on ae71
  2. So i know it has been a long time and I'm a little lazy also it is the worlds longest project have dune some work but not heaps here is were I'm up to the motor has been paited i have a custom bell housing and seaching for a gearbox w series
  3. :) after so much time has past the car is home and i have been busy with my half cut so there are the picks of the half cut not that clear but u get the point so the motor is out and i have started to strip it i through it has taken this long better do i right first time all parts getting painted etc so there are a few of it being strip now some of the painting before after so though i would buy a few things to help it move a bit better adjustable cam gears and a gates racing timing belt pics below so with all the parts looking good could not put it on a bad looking head and block, also wanted to see what the boars looked like so took the head off sent away and got it acid cleaned and skimed new seals etc as u can see in the 3rd photo the boars still have the cross hatch and no lips so all good not going to stip the bottom end any more but am going to get the block sand blasted and painted this is the pics before the block got sent away thats is all I'm up to for now post more soon
  4. am going to put a 4agze in it ,as for the old frame lets just say its dead to us now, got cut up and scraped also have decided to get rid of the reverse lights and going to put in l.e.ds in here are the lights i am thinking of putting in
  5. yeah sorry for the long delay but it has been out of my hands only just got it back from the panel shop the role pan looks good but thats the reason for all the delay i did not have to worry about the spare tyre bracket as i am going to move the spare into the back behind the front seats and probly put a drop tank on it also will try put more pics on more regular as i have the motor ordered and it will be ready for me in about 5 weeks
  6. WOW it has been a long time since i go work dune on this car. my panel beater has struggled with the concept of the rollpan and it has not been dune before i think. We had a few hick ups but we got there in th end here is the pic.
  7. going to paint it a new toyota blue 8p1 window panels on out side will be same colour but inside will be black trim work
  8. no i think it will look better with trim work on the in side
  9. well well well throught i would never post again but i am final back. RESONS for no posts is no movement to much has gone on i have got maried/hunnymoon my 2nd panel beater got put in jail before even touching my car mine u he had it for about 9 months with no work dune but anyway enough of that here is were it is now 3rd panel shop much better straght to work only been there a few weeks and this is what it looks like so very impressed
  10. here it is after repair so now its time to put the panels back in the rear update latter
  11. Hi guy was wouder if u can help i want to do a brake and suspension upgrade to front and rear off my pano so it will be able to take the 4agze i plan to put in down the track the only thing is i would like to keep it all toyota if that is at all possible i have heard the corona mk2 "F" series diff will fit not sure what centre to put in that plus i would love to put disc rear end allso have heard u can use ra23 front struts but just want to make sure if i want big wheels they will not scrub
  12. welding in the flat panels from first shell
  13. ok a lot has happen since my last post so thought i would up date have found my self a new body was going to use it as a doner car but my panel beater said he would be better fixing the new one (no rust) next job was to fix the the big damage to to door so i had to get it to a rolling fram so here the pics so far and now this is what it looks like so far will post more soon
  14. some more of what it will look like
  15. well have started cutting out the rust to put the new roll pan on this ie a preveiw of what it will look like and i have cut out the roof rust
  16. can u put a pic of yours never seen one with only one window on the side before and little hard to see the little pic
  17. its all custum a guy i know made it and it mild steel
  18. not much only $80 all foled spock to the panel beater he said he will give it a go next week some time
  19. ok guys some progress is about to happen i got my steel metal for the rear end and i am about to put this onto this so i will let u know how it gos
  20. ok thanks guys i checked out a work today as i work at toyota and the front end in the secound pic came out on a ke70 from about 11/83 to about 3/84 then the ae71 was born thanks to all for your help
  21. thanks thats y some look the same at the front just never herd of it
  22. do u know what year they changed over to ae71
  23. not sure but i think this guy has put a ae71 front on a ke70 boby just wanted to know if u can do it not sure y u would i have reason to beleave the two cars are the same car and as u can see it has a k motor
  24. thanks dan have gone back and fixed up
  25. so if i get one like yours it should fit yours mine they look the same to me
