starky
    9
Everything posted by starky
  1. does any one know if a 5k manifold will bolt up to a 7k-e head? the reason i ask is because i don't have the time to bugger around with the injection just yet. plan is to buy the donor engine throw it in with the 5k manifolds (if this is possible) and then when i have more fit the injection
  2. do any other toyota engines bolt up in place of the k series? like y series?
  3. you already have a map for the 7k efi? what were your dyno figures?
  4. Hey just putting another question out there. I have just found a reasonably priced 7ke EFI engine Is there anything special needed to put this in? or do i just get the complete loom and ECU power it up and away we go???? I know with newer cars this is not the case because of BCM's ect but hoping coz it comes out of a old van it will work with out much need of an auto sparky
  5. :2thumbs: this is the info i have been hoping for thanks guys.\ sounds like a easy straight forward bolt it apart fron spacing 1 engine mount which is easy?? Still no one with engine weight info???? would love to compare it to the stock suzuki weight!
  6. I have found a cheap long engine. So was wondering will all my manifolds from the 5k bolt on to the 7k???
  7. motor is strong but for the money of reconditioning the head i can scource a 2nd hand 7k then reap the benifit's of lower rpm torque. Sump clearance should not be a problem as it is a 4x4 plenty of room. Mainly concerned that my gearbox and clutch will bolt up to it!
  8. Hi guys. I'm new to the toyota family. I have recently purchased a Suzuki Sierra and it has a 5K lump in it. Apparently the engine and gearbox were both sourced form a liteace. The little motor goes great but on start up and after idiling for a minute when you take off it leaves a great cloud of smoke. so for the expense of re-conditioning the head i was thinking of just shoving in a good second hand motor. My question is will a 7k just bolt straight in?????? or will i have to modify stuff??? Also does anyone know the weight difference between these engines??? Cheers Starky
  9. Hi guys. I'm new to the toyota family. I have recently purchased a Suzuki Sierra and it has a 5K lump in it. Apparently the engine and gearbox were both sourced form a liteace. The little motor goes great but on start up and after idiling for a minute when you take off it leaves a great cloud of smoke. so for the expense of re-conditioning the head i was thinking of just shoving in a good second hand motor. My question is will a 7k just bolt straight in?????? or will i have to modify stuff??? Also does anyone know the weight difference between these engines??? Cheers Starky
