Hey Guys,
After a little bit of waitin round, finally gettin a few things in order for my conversion.
Jus wanted to kno what suspension setup some of you have used in a KE SR20 conversion.
I am using a hopper stopper front brake setup which we are real happy with, and i will be adding another leaf spring on each
side at the rear, to bolster it up a bit, jus incase i want to go bigger turbo later on.
Although, i would really like to hear from some of you with any suggestions on what i should be looking at for front suspension,
bearing in mind this will be a daily drive.
So far: Hilux LSD (Prado diff centre) 4:11
AU Falcon 5 STUD disc brake setup at the front/ drum rear
Exedy Stage 1 HD Organic Clutch (will be running standard turbo and computer)
New Master Cylinder from Hopper Stoppers, saved a lot of hassle.
Just about to get tailshaft sent off and cut to size, then can start on the nitty gritty fab work.
Any advice would be appreciated.
steve
