Des
Senior Member
    3158
    3
Everything posted by Des
  1. Needs more low. Looks like fun though. Good luck with it ;)
  2. +1 for white.
  3. 4k or a 5k. Have a poke around the engine conversions section.
  4. RHR drum sticking after applying the brakes ?
  5. I might bring the Ke11 if it doesn't cook on the way.
  6. Its not finished yet Johny, You need to do something about those springs. Carols springs should be able to sort something out for you.
  7. Condition of splines on the axle and inside the diff center ?
  8. Do you mean it has movement at a single point in wheel rotation ?
  9. don't do it. I'm building a worked 18RG for a mate and its costing him a lot and taking f@$k loads of time finding parts.
  10. Make a set of extractors for Ke1x and Ke2x ?
  11. Fitted a Ke20 KPH speedo to the Ke11 cluster yesterday, Straight swap apart from i had to cut the shaft for the trip meter reset. Even has the same font as the MPH speedo.
  12. LED tail lights ?
  13. Just find a publica ?
  14. I don't run a resistor with my electric dizzy on my 3k. Isnt the resister for the coil anyway not the points evan ?
  15. Looking good. I can borrow my dads trailer for when ya move too.
  16. I like the wheels ;)
  17. Josephville rd on the other side of Beaudesert floods, Goes about 5 - 6 meters under water and the road usually floats away. The road that goes behind bunnings at oxley goes under water pretty easy, Which means no access to maccas, super cheap or harvey norman.
  18. Gaurd to centre of the wheel hub ?
  19. Des
    New Laws
    SPER just doesn't suspend your license. You must have missed payments ?
  20. 4AFC carby would work to solve ignition problems.
  21. Old crown Cressida
  22. Well that depends, I work for star track express so i may be able to sort something out if you can drain it, bag it and pallet it. Thanks mate.
  23. I love P platers. They take the attention off me.
  24. Hey it didn't over heat today when i took it for a run. I'm going to drive it to work tomorrow :D
  25. How does the 5k and toyoglide go ?
