31 -
Everything posted by CaptainL
I change the bearing's just to be sure.....and then I'm ok!!!But... I have and the other one!!!! Tommorow i have plenty of time... :jason:
Ok.....Thanks for the help.... I'm going to check it know and post fotos because I'm very novice to gearboxes!!! :POSTPICS!:
Yes i know it .....much cheaper! Its just for show you!! :elvis: I found this!! http://www.rollaclub.com/faq/index.php?title=Front_Disc_Brakes :rock: For the knukle i think is the same diameter!
I need it to adjust the height and the stiffness of my ca whatever i want!(I plan to run in some drift race). So if buy an upgrade kit for my brakes and stabillizer without change nothing (except wheels) its ok? The diameter of steering knukle is the same from AE86 to KE30? Strut bar is the bar from shock tower to another .
Since i have problem with my 4th gear synchro today i decide to make a round to my local scrap ward! So i find 2 gearboxes! Both of them has hydraulic clutch , 5 gears , same 22 spline output shaft and is identically same...and ofcource has the toyota emblem! I decide to open one of them to check it from inside.....(first time) :jason: thats the result!! The big problem its that i don't know what code is and if it suitable form my engine(4age). From inside i can see that it is in a good condition...i think! Can anyone recognize it?
Hi I thinking to make some update to my front system with better suspension , steering and general to update the front system after the new engine(4age). I search for diy coilover but i don't know what i need to buy! (from ae86 the steering knuckle is the same? ) General can i use from ae86 arms , stabilizer and strut bar?
17 !!!! nice!!! Can u sent me pics???
probably 16inch its not a good idea.... :sob:
That's the problem..... i don't know what fit's at 16inch!!! For example wheel 16x7.5 and tires size 205/40 Approved Rim Width Range (inch) 7.5 and Overall Width (inch) 8.6 its ok or they hit the fender?
Hi!! I want 16inch but what tire to prefer ? 205/40/16 front and 205/45/16 rear its ok??? :glare:
Here is my cars.....
:lolcry: :lolcry: :lolcry: i forgot it.... KE-30 2D
Hi! I want to change my rims and i don't know what size to fit! 16 inch its ok or a problem?? Now i have 14! :wink:
Hi, Yea its very difficult to find in new condition and its very difficult to find a pair from another car!!!! all of then its 30 years old car... so all of them its rusty or heavily damage. I thimk the only solution is to fabricate my own rockers as u said. ..... so tomorrow is critical day for my car(and form me).....and soon i saw you my wheels!!! :dance:
Hi !!! I'm from Greece and searching for rockers (L & R) to replace at my rusty corrola but i can't find nowhere :bash: :bash: Anyone has an idea :hmm: :hmm: :hmm: I can made DIY at a shop that processes metal but i want to avoid it because of the details that i lose....
nobody knows ??? :sob:
Hi!! I just bought a 4age blue top with the tvis and all the cables. Does anyone knows the wiring connections to do it? thanks
the problem is easy!!!its the timing! turn your engine at the zero spot!it has a small edge http://img375.imageshack.us/img375/4016/timingo.jpg then ckeck the cables that is at correct place!! the correct is this! http://img694.imageshack.us/img694/5346/casket.jpg then check the dizzy to point at the number one at the head of the dizzy cap!!if they don't just make it to point!!!! :blush: "ALL OF THESE MAKE SENSE IF U don't MESS IT UP WITH THE CAM....." :hmm: Do it and tell us!!!
hm... so if i want to convert my suspension to coil-over i need to search for ke30 top mounts or from someone else model? were can i found DIY top mounts??
I'm just wondering if the top mount of ae86 fits to my ke30??? :glare:
i have 5k engine with standar cam-shaft and i want to upgraded it at 250-260 degrees!this degrees is ok?engine works fine with this degrees and one standar carb? :hammer:
Hi!!!Back again with new fotos !!!!and modifications!!!!! :hammer: Here with aluminium rims but :lolcry: .... i prefer it with the steel rims!
no is not cruise control! Is as it said very rightly CD_rollaman is the remote for a Sony head unit!! :ninja:
Thanks!!!! :wink: I fix the back lights with leds (hand made)!!!, Mod a little the back ventilators and then paint it :hmm: , Dressed the dash with skin and change the lamps of gauges with white leds!!! Put at the mirror one red led (as BMW etc)to light up the gearshift lever !!! :ninja: At the internal lights made an fade in fade out circuit :bash: !!!and finally I accomplished to place electric windows(only front)!!!! !!!!Line has the central locking and the alarm!!!! (pics of all soon)
