sidetwists
    5
About sidetwists
  • Birthday 10/29/1958
Contact Methods
  • MSN
    sidetwists@hotmail.com
  • Location
    Melbourne
  • Real Name
    Stephan
sidetwists's Achievements
  1. I replaced the leads together with coil and distributor cap. Tried that today, unfortunately no luck. I couldn't detect any change in idle when spraying the stuff over the manifold and around the carby, only of course when some got sucked into the air intake. So there doesn't appear to be an intake manifold leak where it bolts on. Replaced carby base gaskets above and below the insulator, no luck. My coil is a brand new one and it doesn't have a supressor, so that's out too. Now here's something interesting: with the choke on just a little and revving from about 2500 upwards, engine runs perfectly. Take the choke off and drop the revs, it dies. I have then tried yet another carby from an engine I salvaged some 17 years ago still running at the time and sitting in my shed since. With that one, regardless how tight you set the mixture screw, it runs terribly rich, but - it even idles if you can call it that, very very rough but refuses to give up. Move the choke even just a touch, the engine revvs up to about 2500 to 3000 and runs perfectly well, just too rich. And its not the idle screws, I set them at reasonable speed before the engine was hot enough to start its evil game. I am at my wits' end.
  2. The start gas is definitely something I'm going to try :-) But forgive my ignorance, ptc valve, what is it? I only have one vacuum hose which goes from the carby to the distributor, and that one seems to be ok.
  3. What do you suggest might be expanding...because as I said, there are no water leaks, and incidentally no visible oil leaks either?
  4. No, not yet, because as long as the engine is cold, it runs perfectly...
  5. I recently had trouble starting my 1970 KE17 / 3K engine which after much trying would only fire on three cylinders. After replacing both the coil and distributor cap which I found had a crack, that problem was solved. The car then went to a paintshop where it sat for three months being worked on. On return, I now have another engine problem which I just can't work out. The car starts beautifully, idles like a dream and is a pleasure to drive. About 5-10 minutes into the drive when the engine has reached normal operating temperature, it starts to idle a bit rough and gets progressively worse to the point where I have to keep one foot on the accelerator and the other on the brake if I want to keep it running (its an automatic). Take the foot off the accelerator and the engine will stop and not start again until it has completely cooled down. I have replaced the carby (stock standard) with a refurbished one, no luck. I have also replaced the fuel pump with a new one, no luck. Someone suggested head gasket failure to me, but the car has none of the symptoms, no moisture out of the exhaust, no loss of coolant, no emulsion smear from water in the oil or oil in the radiator. I just don't understand what else can possibly be wrong. Any takers?
