You should start off with the larger 212/215mm 4a flywheel which is found behind the small port 4age. Then get yourself at the very least a custom sprung pressure plate. I know there is an off shelf pressure plate to suit this flywheel with 2800lb clamping force. But the guys who built mine have retired and therefore can't get onto them. Contact a reputable clutch place or try Jim Berry clutch bloke.
You should also go for a puck type friction disc but I would stick with sprung centre.
Good luck.
