gt500biatch
    123
About gt500biatch
  • Birthday 08/04/1990
  • Location
    Brisbane
  • Interests
    4age 20v <3
  • Real Name
    Owen
Recent Profile Visitors
gt500biatch's Achievements
-6
  1. what design /measurements for the reverse cone bro ?
  2. thanks for the info guys, ill be getting them made at the coast, and yeh it wont be done dodgy exhaust shop press style, I'm unsure about my exhaust ports will have to measure them and its in a ke70 bud :) and i was thinking of going mild steel to avoid cracking
  3. personal preference.. ill be going for 4-1 rather than 4-2-1 so i don't need to worry about 1-3 & 4-1 being connected. however some say 2.5" tubing down to a 2.5" cat then 2.25" the rest of the way. and the tube length at 28" does that sound good ? @littlered could you measure yours (length) and give me a rough idea how long yours are ?
  4. iv done a fair bit of research, most headers that are cheap have a fair few shitty reviews, if I'm going to spend the money i might as well do it right. I'm currently running those shitty trd copy ones. most proper tuned length ones cost over 1k anyway so might as well get them built ?
  5. hey guys, I'm getting some custom headers made up (tuned length) with mandrel bend and exhaust (with hi flow cat etc) i just need some help in what size tubing i need and the thickness ? they will be 4-1 headers, however I'm unsure to what size/thickness to get for max performance. this is what my build is 4age 20v toda over sized high compression forged pistions C/R 12:5:1 H beam forged condrods ARP head studs ARP crank studs Kelford 194-C racing cams Toda racing adj. cam gears Full head reco port and polish Supertech 1mm over size valves Supertech racing vavle springs Tomei crank caps TRD 0.8mm multi layer metal head gasket TODA timeing belt 1zze Coilpacks ITB'S (trumpets) thanks :)
  6. still rocking your quads dave :) haha and offset fronts are 15x8 -0 rears are 15x9 -0
  7. yeh i can't find it tho :( its somewhere in my room (ʞ©$ɟing mess) 126kw atw, but when i had it dynoed at elite it was 128 with a razorback... but my tuner said his dyno is a lil lower ill try find the sheet some time and post :)
  8. https://www.facebook.com/photo.php?v=10153545971265300&set=vb.648855299&type=3&theater dyno vid ^^
  9. since i got daves old 70 it had a blown motor bad paint dings rust etc... the guy who dave sold it to didnt take care of it at all.. so this is my build thread : :) 4age silvertop 20v the rebuild is as follows (hopefully i included everything) : toda over sized high compression forged pistions C/R 12:5:1 H beam forged condrods ARP head studs ARP crank studs Kelford 194-C racing cams Toda racing adj. cam gears Full head reco port and polish Supertech 1mm over size valves Supertech racing vavle springs Tomei crank caps TRD 0.8mm multi layer metal head gasket TODA timeing belt 1zze Coilpacks ALL ENGINE PARTS BALANCED ITB'S (trumpets) + all RWD conversion parts Fuel system - Bosh 070 internal pump Bosh 040 external pump surge tank other mods T-series diff with TRD 2way + 4.77 final drive Haltech PS1000 Fully adjustable coilovers with camber in front AE86 9KG springs on the back T50 Gearbox Fully adjustable recaro racing seat jdm ae86 calipers, 2022, dba slotted rotors. QFM brake pads ADR approved braided hoses. Quad head light setup (Daves corona made) 2 1/4 inch exhaust with 2 resonators and 2 sausages (no exhaust noise, only motor GRRRRR ) 4-1 extractors Fresh Paint, No Rust, No Dints, UBER UBER pumped rears to fit 15x9 -0 hope you like :D iv got heaps more pics of the engine build, cbf uploading but you get the juice of it :) vroom vroom
  10. yeh iv emailed fat fitment i heard they do it. see what they say, my lil bro had some bloke from the coast come do his e30 beemer and did a mad job so ill see if he does it still,
  11. haha i have wheels that fit, but not enough dish :( haha iv got money to spend, the thing is its overdue for a respray etc .. so i wanted to get this done before. i don't mind paying a lil extra to make her look better, I'm not gna spend cheap money and get a cheap job, one thing iv learnt is you get what you pay for. :) thanks for the input lads :)
  12. mmmk theres a bloke selling weld on guards for 150 they are 70mm to fit 15x10 -5 .. but I'm a noob when it comes to welding, as far as i can tell its alot of work cutting the current ones out (inner and outer) then re welding... is it a bitch for bolt ons aswell ?
  13. nice, did you flare the fronts too ?
  14. yeh i think my ride height is around 75-80mm... i will be running - camber on the front. and i am leaning towards bolt ons on the rear, but unsure whats what on the front in terms of clearance :/ :(
