If its the same road I'm thinking of (just inbetween 2 creek crossings) you should be able to make it up. My dad made me take our ae95 up there waaaay back when i still had my L's. diff lock wasnt required either heh.
Daniel.
Cutting your springs that much will make it handle worse so it would make your 4age a little less fun :ninja:
with the cam covers i would go the 'D' option and then sand off the tops of writing back to metal would look awesome!
Daniel.
Hi
I would check your idle mixtures, choke and throttle position valve (if fitted) then the float seems like a good place to check.
I always use a container of water to get it right (don't get the accellerator pump wet however) otherwise correct float to a unopened 4k carb is aprox 7.5mm from the top cover of the carby top.
hope this helps
Daniel.
Hi
not sure if this helps but from memory:
Holden vn style hubs and discs will bolt onto a ta22 stub axle (could have been ra23 style axle)
Ms65 crown hubs will fit onto a ma61 ra60 etc stub axle and have a 5 stud pattern which is the same as a hilux and ford.
however this is off the top of my head so research these options fully before buying parts. Both these type of swaps are documented somewhere on toymods I'm sure.
Daniel.
