BBQ_Rolla
Regular Member-
27 -
Everything posted by BBQ_Rolla
thanks for the help. but now i have to make it look like a granny car. Sic that means i should white walls and a sunvisor on it.
will ae86 extractors fit in the engine bay.
Do you reck'on if I had the exhaust come out just before the back wheel, it would be legal?
Ok finally gonna stop looking at all the bits and pieces laying around in the shed and start putting the 4age into my car, seeing I lost my liecence for trying to drag a unmarked cop car. Does anyone know where I can get a manifold to fit two 40mm weber side draghts? Whats the sieral number or name of the bearing that i need to get for the flywheel? Can i use a AE86 water pump? Or would it make things worse? Do I have to shim the bearing if I got gearbox out of a AE71, which was bolted onto a 4A motor? I'll start putting pics up of how it coming together when I start. Thanks
Don't think so mate, here some pics of the car the 4age is going in. Did go to sydney to get a green ke25 though.
Hi Slowly getting all the parts together, the parts that I have sourced so far are: An AE71 full car still running with a 5 speed An AE82 full car with a blue top 4AGE Surge tank and electric pump and bigger feul lines. Now I've pull the 4AGE out and started cleaning it up and taking it down to a bare block. when I put it back together what parts do I use? - Water pump And plumbing do I need? - Alternator? - Flywheel? - Clutch? - Radiator? And which gear box leaks oil? I think that all I need help with at the moment. I will be pulling the get gearbox out of the AE71 next week a having to much fun in he paddock with it at the minute.
Aus Motor Racing Championships (this Sunday!)
BBQ_Rolla replied to TheNOBBLER's topic in VIC / Melbourne
what are the police like down at calder. Just lowered me car a bit to much, it fails the coke can test, even laying down. -
I missed the lasted cruise, but proably better. About 48 hours after I got my motor going I broke my 2nd conrod at 7500+rpm. If car got new motor by next event then I should be there.
Just brought a 1987 ae82 with a blue top tiwn cam motor in it, and I need help on which parts I need and where to find them to put this motor in a ke55 coupe. Will the gearbox off the K-series motor bolt on to the motor? What flywheel and clutch do I need? Engine mounts, will Ae71 engine mounts bolt straight onto the Ke55 cross member? Do I have to storten the tail shaft? Any help will be great. Will be working on it every night and weekend. Couldn't find any threads, the search thing is no good. Pics to come soon Thanks
Might not be able to make it. blew motor in car and can't get timing right on new motor. already got old motor out. just waiting to get timing right before I put th 6th motor in.
should be there. I'll be in the second cruze. just broght new tyres and they hug to the road like no tomorrow. hope you's don't mind truck spotlights on a rolla. plus I need more stickers for me car how do I get a rollaclub sticker for the wind screen.
Hi I have ran into a promble I order new tyres for my jelly babby mags when I have no wheel nuts to use. Can anyone help, by telling me the specs of the thread of a Ke55? thanks
yeah lets go. cars going great and might put a cam and worked head in it this weekend. the head has 350 valves in it and a sh@t load of other stuff done to it.
I heard last year every car got road worthied by the police on the way out. even the show cars that where on trailers.
The diff is a celica lsd think its been cut down.
Hi Got a a diff out of a Ke10 the other day and wondering If it will fit into my Ke25 project? Reason is I want to do this is because it is a bigger diff with custom axels. Any help would be great.
Got the tuned extractors and mufflers and resisnator. just need pipe and it to be welded together. I want it to crackle when I use the gears to slow down. (what a brake pedal) I got a little yellow birdy off the police last year for having no brakes. All I had to stop was the hand brake and the gears, mostly always used the gear to slow me down. went a week with no brakes till they got me. :P
Is there any chance that the extractors will be able to fit in the ke55 or ke25. I have several corollas, started to that some to scrap metal. Take all the good bits off first though. Had 8 now down to 5 and might be buying another this weekend. :P
Was thinking about putting a SC12 on me motor Plus with the exhaust with only the rear muffler how loud would it be, already been told off once by police for having only half the exhaust with only another resonator bolted on. Will a ke10 exhaust fit into a ke55? I had a exhaust a month back that I welded a fergy exhaust on to the end because my rear muffler fell off and welded a pipe where the resonator went. Sound like a very loud fergy and blow 4 foot flames when I dropped it from 4th to 2nd. :P
Hi would Crow Cams be able to do the Wade grind?
Hi I'm all in confusion :) I have a red ke55 1980 model coupe.(try and post pics tomorrow). I was wondering what would be better for the little rola. I want to get extractors no doubt about that. But this is where it gets interesting:hmm: Should I do a 2" exhaust all the way with only the reaar muffler and a huge droopy tip? or Should I go 2.5" from extractors then to twin 2" with two resonators and get them to put a muffler on each side of the car with two huge droopy tips? :P Plus what ya's think's of stainless steel exhausts? please reply
I had my resinator remove from mine and u could hear it miles away
Yellingbow is near Hoddles Creek, Gembrook way. I'm more hoddles creek than yellingbow. Just dropped in a 5k with 4ml dished pistons and 3k bigport head, goes like sh@t:n, Need to find some extractors. :hmm
Hey All I Own a red Ke55 coupe with a black bonnet and spot lights. I come from yellingbow area. Probable seen me side ways some where (on me 3th diff).:bash Me got a 5K with weber followed with a 5 speed. Hadn't been out driving because doing a motor rebuild. Whats the best cam for a 5K With a compression ratio of 10:1? Pic of when bought, will get current pics up soon. Gotta love old cars, the whole car shakes with two 12" subs. :lolcry
