mike100
    19
About mike100
  • Birthday 11/25/1966
  • Location
    melbourne
  • Real Name
    Mike
mike100's Achievements
  1. like your garge fx gt as well cool
  2. installing the blacktop into ae100 was there much hassle on wiring the engine up to the ae100 loom
  3. with the 275mm rotor upgrade you used st202 caliper bracket holder where there any mods to make fit or is just a bolt on job. what are the part numbers for the 275mm rotors.
  4. i seen you tube video recognized takanini straight. southern motorway overpass.
  5. where did you get 240k speed o from , are you from manurewa south Auckland. i grew up there. your rolla looks cool.
  6. cusco coil overs is the ride firm , i have them in my rolla and the rears need softer spring rates
  7. hi ae112 will fit however the ae111 shock is shorter so the wheel alignment will out, i tryed this ae101 corolla as i have ae111 full suspension fitted,really pushes a lot of angle on cvs .do you want after market shocks? or original ones fitted, looking at original ones from toyota for ae111 bzg they are not that pricey anyway.
  8. my corolla ae101 runs 4age 20v with c56 5 speed revs same as yours on freeway at 100k 14 inch wheels , sounds fine to me.
  9. check the indicator relay, or bad earth some where.
  10. got my cuscos in an wheel aligned sticks to road like go kart.
  11. ae111 standard ecu
  12. any one know of a workshop in melbourne who can PROPERLY tune a 4age 20v bt with adjustaable cam pulleys, i have a iiregular miss at about 3000 rpm ,i think the timing is out .
  13. get my cuscos zero1for ae101 in jan
  14. just fitted 60mm velocity stacks loud induction now.
  15. hey dude have look under the seat the rail of the 06 seat should be bolted to the base, your seat rail should bolted to base as well measure the rail bolt points may be same lenght see if you can just swap rails should bolt straight in. i swapped ae112 seats to ae101 they bolted straight in didnt have to do anything only change the seat belt over.
