brm
Everything posted by brm
  1. I need some help in identifying this strut. I have searched wreckers comparing various struts and found none that match. Dimensions are as follows: Steering arm/Ball Joint mount bolt hole centres 85mm Brake caliper mount bolt centres 89mm Thread in strut 12 X 1.5 mm could have added as all caliper mounts I have seen have thread in caliper slide not strut Stub axle bearing diameters: Inner bearing 31.5mm Outer bearing 19mm Seal 48mm same as XT 130 and other large stub axles I have seen Tube diameter 51mm Part number shown on tube TOYOTA -340.4.8.084 From my investigations I can rule out the following vehicles XT130 KE 70 ST141 MX73 Celica I am unsure of exact model 62 or 63???? Need your help to match these and find another pair to make into coil overs. Thanks Ben
