Dixon
    9
Dixon's Achievements
  1. Some pictures of body work from summer 2010. Last one from 2011
  2. No.. Maybe in my phone is one picture when i change front fenders last autumn..
  3. Little bit pictures what i have done to body. Shaved and modified front bumper with Golf mk2 clear turn signals. Self made front lip.
  4. And here almost every e7 is 2d, i buy 4-door when i find good and original condition..
  5. Little information about what has been done to engine: - Self made parts: oil pan, oil strainer, engine mounts, water outlet and by-pass pipes, intake manifold/plenum, modified 5S-FE exhaust manifold, 2" exhaust pipe etc. - starter from rwd 1C engine with 4K starter pinion gear, radiator from T15/T17 carina or E8 corolla, SV-21 alternator - 3S-FE flywheel and pressure plate, rwd 1C clutch disc, added crankshaft spigot bearing, rest clutch system from: CA-60, EE-90 and TE-71 - 200cc injectors, gen2 3S-FE throttle body + TPS, AE-86 fuel tank and fuel pump. - MegaSquirt 1 v2.2, wasted spark, 12-1 trigger wheel, innovate LC-1 etc.
  6. My other E7 project. Also -83 2D originally 4k, k40. I have a third ke70 corolla but it waits restoring. "Hidden" under the hood 3S-FE engine, W51 transmission, CA-60 rear axel with 9" brakes and lot of self made parts. :rolls: Engine runs now but it has litle bit work before i can go to test drive.. :huh: Pictures are little bit old but shows condition.
  7. It's from Crown s110, grill is Corollas own.
  8. XXR 513. Front 7x15" ET10 or 15 (don't remember right now) and rear 8x15" ET0 Tires: front 185/45 and rear 195/45.
  9. Hi I'm Janne from finland and my corolla project and daily drive car KE70 -83 2D with 5K engine and K50 transmission and 9" rear brakes. I have this for 6 years so far. :) And here is few pictures at the condition right now.
