Ella
    1126
    4
Everything posted by Ella
  1. No they wouldnt.
  2. sure... 8000 bucks, comes with a free car.
  3. rust the killer of all good corollas lol. cut that scetion from a good donor perhaps?
  4. cheers spencer, yeah rian xt130 contol arms and struts with cusco camber tops, every single bush in the front end is brand new urethane too, rear end has re bushed control arms with toyota genuine rubber bushes, and urethane bushes everywhere else, cut and reset jeep cherokee front springs and suzuki sierra heavy duty shocks. oh and the colour in real life is much more like the first pic (lighter) and has glitter in the clear coat lol. the paint job is a bit rough but still ten times better than a unpainted one.
  5. ok so no headlights in, but i did do just a little bit of work to it. suspension, wheel alignment and ride height in front and back are all sorted! ill let the pics do the talking! before height front corner shot new height shot front corner shot showing new camber, caster and toe settings (kinda lol) what do you guys think?
  6. hrmm find out how much, would be keen as i eventually need another motor, might be nice for a rally bash too hahaha
  7. of course ellas keen, lets make it happen!
  8. If you want i can do a install on it and hide the stereo somewhere out of sight (thinking in the glovebox)
  9. it depends how low you go, generally someone with half a brain upgrades the shocks at the same time, stock shocks don't cope with upgraded springs anyways
  10. dude, is that PVC intercooler piping!
  11. Ella
    Rians Ke70
    ah so you got new stuff after all, how cheap/expensive was it? i am starting to need lines for my dxs new brake setup and have been considering getting some new steel lines
  12. i got a LSD center for this on monday! will have to attempt to slip it in on the weekend i think :)
  13. sorry guys but this is all so very wrong. cutting springs IS ILLEGAL buy proper lowering springs, they can be had in all shapes and sizes. being young if your cars lowered the first thing the police check is if the springs are cut....
  14. Ella
    Rians Ke70
    don't bother bro i have one here you can have, for free.
  15. ill give you guys an idea... its BIG lol
  16. thats a good price for a tune
  17. maybe once the headlights are back in :)
  18. hrmm long time no post again, as per mt previous posts have been busy moving house. new place is so much better! finally moved this and the DX on monday so they now live under the new house. had a few spare moments so i chucked one of the new wheels i got for it (cheers chris) on so see how it test fits.... what you guys think?? :)
  19. jetted nicely they work just as well as a 32/36...
  20. lol just pull the head and do the measurements if you don't think itll be ok bro. use the usual method to work out the swept volume of the pistons and a syringe to work out the CCs of the combustion chamber.... i roughly did it one night before i assembled it and it *should* be ok with a decent tune and good pump fuel...
  21. Ella
    Rians Ke70
    quoted for troof
  22. reed and car hung out at my place today for a while, reed got lots done i mostly whinged about how sore i was and sat down a lot. But i got the idle sorted too. It wasnt any map sensors or the "tune" or anything like that just the plain old idle adjustement on the throttle body. Although the lack of an oxygen sensor is likely attributing to his light overfuelling (its not that bad). I'm sure Reed will update more once hes made it home.
  23. Hey man, good to see you got some use outta them bars :) Will be watching this one, your doing cool things.
  24. You can't tune a 4age ecu, at all.
  25. Ella
    Rians Ke70
    this is how mine are done man and they came out good and safe although mine have locators drilled into the struts too lol. even so with the weight of the car pushing down on said threaded tube itll be all good. maybe you ground too much off as it should be a tight interference fit.
