rpm_sa68
    8
  • Real Name
    Sam
rpm_sa68's Achievements
  1. Exactly what I'm after cheers! :yes:
  2. Red Dwarf.. I wish to Fit Watanabe 13x6 4x114.3 pattern to my Ke10 (4x110)
  3. Thanks for feed back guys, How do spacers work? Do they widen the track at all when used?
  4. does anyone know if its possible to convert 4x114 to 4x110 to suit Ke10 pattern?
  5. HI All, Just inquiring about what is available to purchase as far as rear shock absorbers go for Ke10 corolla's? I intend to get the rear leaf springs reset and possibly modified to get a 1 inch above standard hight. Also Will a standard factory spec shock be able to operate to a good standard if the ride hight is raised?
  6. The Vehicle is a Australian delivered 68 ke10, ke20 struts fitted. I already have koni red adjustable's and would like to work with them for now. I will measure OD and e mail ground control to confirm the compatibility.
  7. Ok thanks, also any suggestions for a spring rate? appox 800kg, rough gravel driving.
  8. How/what is measured to determine if a O.D. strut housing is SR5 50mm or not SR5 45mm? I ask in relation to ordering a Coilover Conversion Kit, 71-73 Toyota Corolla (Front) from ground control.
