gilly40k
    38
About gilly40k
  • Birthday 03/12/1990
  • Real Name
    Jake
gilly40k's Achievements
  1. And ecu will I have to upgrade it? Or have it flashed?
  2. Ok well am getting cams regrinded because I can't find perfomance cams so I have gone next best thing I am thinking the intake manifold will have to be machined to the port size? Same with exhaust?
  3. May think its stupid bits its what engine I wanna do up so if u want to help me feel free to post if not don't post at all thank you
  4. I beleave it might be first gen
  5. http://i48.photobucket.com/albums/f202/jarryd_t1/4A-FEAE95.jpg this Is not my car but I found one that is close to mine
  6. It says 16 vavle efi
  7. And yes I was looking for a black top
  8. I just want to know what work to do to this head while its being reconed like ported polished over sized vavles stuff like that to improve power if I do any of this work do I need to change anything else?
  9. I want to keep the 4afe not replace it I only just fitted it to replace the 4afc
  10. Could not find a 4age so and the ones I found where asking $1500 just for head and block no inlet or gear box or ecu.. So I went 4afe
  11. I have a stock 4afe I want to get the ports done polished and bigger and over sized valves but I want to know will I need bigger injectors or any thing like that
  12. Yeah I checked it out they r loose how tight r they ment to be?
  13. If you do this this way more costly you are better off buying a complete 4afe and reconditioning it. What I did is buy a complete 1993 corolla wreaked (tail gate) then re build it and buy a engine recon kit
  14. I just changed my engine a week ago the tanks r the same u just need fuel Pump and lines the loom for the dash and a engine loom the heads r the same depending on the gen of the 4afe the blocks r the same different water pumps and the belts r different they run the same gearboxes and engine mounts also ur exhaust is the same just minor things changed
  15. I just changed my engine a week ago the tanks r the same u just need fuel Pump and lines the loom for the dash and a engine loom the heads r the same depending on the gen of the 4afe the blocks r the same different water pum
