28 -
Everything posted by madtoy308
try get some pics up soon,motor in,gearbox mount made,exhaust on,all ready,just getting supercharger serviced...looking for a ke20,pre licenced...I'm in perth
hey guys,been sleeping for a long time....ive done 308s into ke's with no fire wall mods and on a low budget.....just dropped a smallblock chev into one and had dramas...yeah there narrower,but exhaust is a headache and firewall has to be cut..(use 2mm plate minimum) i moved mine a foot back so dissy is under plenum..runs a turbo 400 so made new trans tunnel..bit of work but well worth the effort.... the thing screams. madtoy lives on!
hey all,does anyone know where i can find some 3.5,3.7,3.9 diff gears to suit mini borg warner diff for my ke30...ive only found 4.1s and 4.3s so far!!! does anyone know if corollas came out in other ratios that will fit????? any help would be great..thanks p.s. my diff has inspection cover on back.
thanks guys,found someone that has video footage,just need someone to put it up on rollaclub...
just wondering if anybody got my corolla on video at motorvation??? i was in burnout comp on saturday afternoon...blue ke30 v8...or,let me know what you thought if you saw me in action...thanks...p.s i had a few people come up to me from rolla club,but sadly it was when i was busy or couldnt talk...sorry guys.was free sunday for taking people for a lap or two...
don't go to veem,go see phil !!!!!!!!
phil purser,final drive eng. in oconner
no harm done,was a good debate with rolla boy,hope we see more pics of the car soon...
yeah mate,ive bought 4 ke 20s in last few monthes,just selling what i havnt used! and the two i advertised ive sold for $550
front end drops inch,lower back 1half inches and ur right...go the v8,forget the v6...he he
if your going to bother with a v6,its easier to drop in an 5ltr....theres not much in it,the sump fits between the front cross member and sway bar...but go with what you want...cya
hey guys,october is bit soon for me....will pen it in for next year...wasnt gazzanats early in the year???? if its early next year would be good....and yeah offer stands,i will give any rolla member a ride....as for the new project,i havnt had alot of time lately but i will say its getting out of control....I'm too busy getting my other rolla ready for the drags which starts soon..
gazzanats?? mmmm,thats only a day or so drive isnt???? whens it on??????
hey dan,thanks for that....let you know when I'm going down drags next....
hey guys,i can answer that!! i used hilux diff out of 1978 hilux,later model diffs after that year are too wide..i paid $150 for mine from wreckers,but you need to change the centre before you do anything!!! mine came with 5.9s,now you can't change just the gears,you have to change the entire centre!! carrier changes with different gear sets!! i picked up a highace van centre with factory lsd and 4.11s for $90....also these diffs are 30 spline factory axles,there basicly cheap and bullitproof!!! you need to have spring hangers on the diff moved slightly,i had this done and a custom tailshaft made with new axle bearings done for $400......so about $650 all up depending on what you want.................tramp rods,go to wreckers and get lower rear control arms off 82-84ish rear wheel drive corolla,then get lower rear arm mounts off 1990 front wheel drive nissan pintara,these are bolted on via two bolts,they simply bolt under stock corolla leaf spring mounts..the front mount requires a fabricated triangular bracket..which you need to make yourself...all this basicly gives you tramp rods and only cost me $80 pair..............................PHOTOS!!! ive sent dan some pics of madtoy,hope he got them and can put them on here for me,so hassle dan..he he he... hope all this helps..cya
oh and yes have already got gen 3 and two ke20s,am planning to fit cam and nos first,then turbos....see what happens....i walk the walk,not talk the talk....cya
hey caibs,that was a fun drive,you talking bout emmet from melville???? he he he think hes still got shit in his jocks the day i pulled out onto leach hway doing 60km/h,spun madtoy into two 360s then powerskided up road.....
all i can do is laugh!!!!!!!! power steering???????? yeah I'm going to mount pump in the boot,then run a chain drive around the tailshaft!! should solve the leaks..he he he..bring on motorvation i say...any forum member on here,turn up at motorvation next jan will get a free lap around the motorplex!!!!! cya
hey guys,going with a older box cause there cheaper to rebuild than a new turbo 700 that came with motor...and its for the drags,a 4speed auto is gay!!! I'm setting the rear end up like murray kiethers ke 20...its worlds quickest untubbed rotary street car and its here in west oz...keep you posted..oh and yes turbos are now 500+ hp each... also I'm seriously considering bringing madtoy over to east coast for powercruise,springnats...the car will be left in storage in penrith..still planning it though...cya
hey guys...ive decided to use either 2 speed powerglide or turbo 350....and its for the drags,but I'm thinking street car looking as much as possible...going to keep it untubbed,just going to fit biggest tyre possible!!! and as for turbos,ive found a guy that going to suppy them,hes let me borrow two already to make manifolds.........and the turbos will be mounted above the heads and above bonnet line....as for paint,its going to be matt black...get some pics to you all once ive mounted turbos....oh and thanks for the encouragement guys,I'm commited to do this project to prove a few people anything is possible...
hey guys,started a new project..ke 20 with gen 3 v8.. just in middle of fitting engine and havnt thought of what gearbox to use.has to be strong!!!! also after two turbos,rated bout 200+hp each...any help would be great!
go for it mate,ive dropped in a 308 in mine...and id say all the losers that put it down are still dreaming at the keybourd!!!!!! it makes me laugh to read all the wannabes put down and take piss out of someone willing to drop in a v6 into a corolla,give it a go and let us know how you went..
........it sits half inch off firewall and i run twin thermos...no room for a flex fan....radiator mounts under front rad support...everything sits behind grill and bumper for a factory look...my engine runs solid cam,vn style efi heads and 750 carby....
calvin.......ive got 308 into ke30,just modify front x-member,no firewall mods needed...I'm thinking of making a kit to sell........and yes $1000 will get u going...the power skids are amazing.....just an update,ive recently run 12.79secs with 185/60/14s,huge amounts of wheelspin...I'm currently fitting 15x7 weld racing wheels with 235/60/15 ET radials....all under standard wheel tubs!!! ive also discovered a very cheap way to make cal-tracs(like tramp rods) which bolt straight to underside of leaf springs,and mount to front of hanger using a fabricated bracket!!!! These arms prevent diff twisting and stop axle tramp,using pintarra parts...thats all I'm saying for now! but i think alot of rear wheel drive yota boys will be happy with my solution...keep you all posted.............madtoy
current car....308 powered ke30 corolla...at almost 200kmh,the vibrations are incredible...
