Token
    38
Everything posted by Token
  1. Line up all the 'dots' on the timing sprockets. So line up the camshaft with the dot on the thrust washer, (before the sproket goes on), then you line up the crankshaft dot with the dot on the camshaft sprocket. i think the canshaft sprocket dot faces inwards and the crankshaft one 'outwards' if that makes sense sounds complicated, needs a picture to explain, just look at your manual. ( you have a manual right?) I had this problem after rebuilding a 4k, turned out I had the timing 180 degrees out...
  2. Thanks for the offer, But really just looking for a decent runner at the moment. Already got a head and extractors etc.
  3. Alrighty, After a 4k, Preferably running but I'll rebuild if nessecary. Cheers Token
  4. Looking for a conrod bearng's (bigend) standard. seem to have lost a set whilst moving 0.o although... ill take a set if someones got 'em lying round. (I know i can get them ordered in... but thats not going to happen till Monday ><)
  5. Token
    Roof Racks
    Sedan. Wagon racks wont fit the sedan? (curious, plan to go wrecker hunting on the w/e)
  6. G'day Fella's Looking for a set of roofracks to fit a ke30/55 ACT pickup preferred Cheers Token
  7. It turns by hand, but its tight, guess i might need to pull it out and recheck torque settings. It's fired up a couple of times, but never idled properly. So i rejetted my weber, and whilst doing that realised i had a few manifold leaks. Fixed them, and thats when it started having issues with the starter. Already tried cranking with jumper cables from a running car, same deal, starter engages flywheel, but wont turn motor. more info on the earths from starter motor? I'm running a starter relay, which has a decent, not huge, but decent earth, but the only wires coming off the starter itself are the switch and the power. Do i want a dedicated earth on the starter itself? if so, where does it hook up? i was under the impression the starter earthed directly onto the block when its bolted on?
  8. G'day All, I have hit a slight hurdle in the last stages of my ke30 rebuild. It would appear that my 3k starter isn't strong enough to turn my motor? I can hear the starter engaging the flywheel... it just doesn't turn it? Iv swapped battery's, Checked Earths and swapped the starter with another 3k, but no dice. Is it possible to get a High Torque starter for the 'rolla? and if so, who makes them? Cheers
