Darren
    12
  • Real Name
    Darren
Darren's Achievements
  1. KE 20 COROLLA 1971 + PARTS KE 20 COROLLA SUIT PARTS MINUS MOTOR AND GEARBOX AND OTHER BITS AND PIECES ALSO COMES WITH SOME OTHER SPARES I ACCUMILATED OVER TIME, THERE IS A 4 PACK SET OF BRAKE SHOES (NEW) IN PACKET AND 2 NEW PLASTIC INNER DOOR HANDLES NEW IN PACKET, AND 2 STARTER MOTORS AND ALTERNATORS AND SOME FANS SPARK PLUGS NEW ALSO FRONT UNDER DASH CONSOLE, ALSO DRIVERS DOOR AND BOOT AND REAR BUMPER AND 2 SIDE BACK WINDOWS AND OTHER BITS AND PIECES, $150.00 THE LOT (EXETER)
  2. CAR NOW SOLD!!!!
  3. Hi again this is the add when i brought motor that says whats been done to it 3k toyota corolla race engine (water pump to pressure plate) it would suit a old school corolla road car maybe historic race /rally car the engine is blue printed built from 3 engines to match weight (rods and piston) it has done to it new valves new valve springs new rings and bearings lightened flywheel to 9 kg matched ported head and inlet manifold twin outlet manifold new water pump new fuel pump new plugs and leads GT 40r coil new points same as holden red motor new cam gears and chain a GT cortina grind camshaft the fly wheel and clutch were balanced together 10;1 compression 4k dizzywhich has had a tickle up
  4. Hi all thinking of selling my unfinished project 1981 ke55 corolla with 3k engine and 5 speed box motor has done little work since rebuild have reciept from bloke i brought motor off $2000 reciept for motor alone to finish off just needs reg which it is still in 3 month period and a exhaust system currently is running a header pipe body is pretty good for age left habd side guard has a little damage back seat a bit worn has only 117000 klms on it has owners manauls asking $1450.00 as is
  5. Hi just wondering if anyone has a set of extractors to sell to suit a 3k toyota engine ?
