cuzzo
    798
Everything posted by cuzzo
  1. Hey guys and gals, My friend has a ke30 2 door sedan but on the factory complience plate (seatbelts and etc) it says its a 4 door sedan. Now this also doesnt seem like its in its factory location on the firewall. It also says its a 4/77 but from what I'm aware the 2 door sedans are only from late 74 to early 76. Any help or pics of your 2 door sedan plates location or details?
  2. Hey, If your interested in non-competitive track days...toymods event section you can find a quarterly event. Adam
  3. Lookn good bud. Pity bout the paint on the wheels, maybe polish it off? So what engine is going in? 7mge? Adam
  4. You may need to research the coil manufacturers book. Surely there would be an aftermarket replacement coil. Something bosch comes to my mind.
  5. Yeah you could put a 1jz or 2jz in there but not with a gearbox or any other bits hanging off the block. You could put a drop bear in there too with out firewall mods but it wont handle very well!
  6. Wow thats some huge rotors! Will the extra weight on the stud axel be a problem? Most people upgrade to the corona strut when doing brake upgrades which gives them a larger stub axel?
  7. I looked at the ke70 you have gav and didnt know it was yours.......thinking to myself.....Jeez this corolla is so neat and clean and tidy......Now it all makes sense it was a 'GavClassic!'
  8. Theres a 2door ke30 at PickNPay blacktown ATM quite rusty doors. most things ok. dash cracked
  9. Whats with the matt black everything in the bay? Looks weird i thought it had caught fire and burnt everything...
  10. Last i heard this was getting sold :yes:
  11. Fook me, whats ur 60footer? edit: i still don't understand how????? isnt there some maths against that? 114mph i would believe but WTF? double edit: i have used a few online calculators (not sure if accurate) and the all say they mph would have to alteast be around 118mph. Thats going on weight = 1Tonne and 300horses. I'm not doubting the time just the speeds.
  12. The first (leading?) time, the speed looks incorrect? I don't think if you go 104mph you can trap an 11 :yes: Also can i add 1:12:00 for my ke30 4agte at wakefield park NSW BTW are these natsport / official timing results or gps based times ok? Thanks.
  13. KEH? How?
  14. Some serious plans for the 10 here mate. I guess once you get the front struts sitting correctly you can look down the path of VR upgrade setups. The only thing that will limit you is wheel size. Oh and having to run a ghey wheel stud pattern :yes: Good luck with it mate! If your chasing high power numbers go a GT2871rs or even a gt30 however it will make the car f@$king crazy to drive. Even with 200kw atws it will be scary to steer on full boost. GOT TRACTION?
  15. Hopefully ill be there. It will be my first one ive missed in 3 years.
  16. No problem on the harrasing me. As long as they aren't stupid questions, or broad questions I'm happy to help.
  17. Instead of moving it, its much smarter (more expensive) to move it to the boot. Why did YOU move it? Just to put a fuse box there?
  18. Hey mark, What fuel pumps are you using? Also are you going to run them inside of the car or outside? I reccomend outside.
  19. Ahh fk it, i may not have even created the thread. Do ke36 doors fit onto a ke30 2 door sedan? haha mods know? Deleted this one.
  20. Hey, It was similar to that thread linked: It was about putting ke36 doors onto a ke30 2door. Thread title something like KE36 doors onto ke30 2 door sedan. Now I'm starting to think did I actually created the thread..............?
  21. Hi, So after a thread i created was closed before all of my questions were answered, therefore i then created a new thread to get clarification on the final question i was asking, it looks as though that second thread has now been deleted and removed? Why is this so? Thanks, Adam
  22. As the title says. Will ke35 coupe doors fit on the ke30 2 door sedans? Alternatively will ke36 / ke38 doors fit? Adam
  23. cuzzo
    1jz Ke55
    Hey, You i guess you can adjust the pinion angle by adjusting the 4 link setup? Or would the suspension stop you from moving it back/forwards?
  24. Did you get the pinion angle set correct also? How many degrees did you get it set at?
  25. Is she making a return to wakefield?
