RocksRolla
    19
Everything posted by RocksRolla
  1. yeah its a early flat front, thanks mate
  2. Hi, I have a blue Ke70 XX, the colour code is JE, but everywhere i have been don't have the colour, it looks like this http://www.ae86drivingclub.com.au/forums/showthread.php/99-blinded-s-KE70-build i believe its called opal blue but does anyone know what the colour actually is?
  3. Ah just a bit of surface rust on the roof? white ke70's are mad.
  4. You may have problems with accuracy, GPS's are not too accurate sometimes
  5. Ah thats handy, thanks for the help
  6. Hey, has anyone changed their rear seat belts in their car? Just wanting to change to retractable seatbelts and i was wondering if any seat belts would bolt up or i would have to get them from a specific model. Any help appreciated, got told not all seat belts will work, some may be too long. Thanks. :y:
  7. Still having problems, found that about three vacuum lines are blocked with screws... ill have to get connectors
  8. 31st July 2011 ALL MAKE SWAP MEET For ALLcar enthusiasts. At Greyhound Park Function Centre, Days Road, Angle Park Gates open for SELLERS at 07.15 am. (enter, from Angle Road ) BUYERS from 08.10 am to 12.10 pm Sites; $15.00 (2 Adults only Others at Entry Fee.) - Entry/Buyer $5.00 each.A CUT ABOVE THE REST' Presented by Club Automobile Francais, Inc
  9. Very nice
  10. Thanks for the link
  11. Ah yeah never thought of eBay, thanks!
  12. Oh so more then the celica and the ke70 used those lights, hope i have luck finding them.
  13. I'm from adelaide :( and ill havr to suss out repco or something
  14. Hey, my flatfront head light has blown... i was told that i have to replace whole light? I was also told there were celica lights that fit, anyone know what model celica? Any help appreciated
  15. Hey been having trouble with my ke70 lately. My car wont idle, causing me to run my car while having the choke on a little bit and as soon as i take the choke off, it turns off. When I'm driving along and come to the lights to stop, the charge light comes on and it turns off, but i think the charge light comes on because its on when the ignition is on. I have checked the fuel lines for blockages, because it started to do this when i had less then a quarter of a tank so i thought it could have caught something that was in the bottom of the fuel tank. I then took the air filter off sprayed some carby cleaner in and adjusted the idle a little bit and it was idling without the choke on and it wasnt running too high, but would stall when i reved it. i checked the vacuum lines and noticed it was sucking too much air, plugged them. still having problems... are the vacuum lines supposed to be plugged? i also added additive to the fuel to clean the carby... i got told there maybe a switch of some sort? because it is reved it seems line it opens something and it stalls... it also doesnt matter whether the car is warm or cold. i got no idea what is going on. :hmm: any help is appreciated :yes:
  16. Hey, in my ke70 i have a 5k block and a 4k head, i want to put them together... do i need to use a 4k head gasket on the 5k block or 5k head gasket, when bolting them together? the bores are smaller on the 4k head, so it will overhang the bores... but the 5k head gasket will fall a little bit short of the bore? probably a simple answer but need advice, hope this isnt confusing :bash:
  17. I use 'T Cut' its really good stuff, its only like $15 a bottle too hope it helps
  18. Thanks! found something http://www.rollaclub.com/board/topic/1389-ke70-ae71-data/
  19. Hey, I've just started to take interest in corollas and I was wondering whether there is any obvious difference between Ae71's and Ke70's. I understand that they have different engines but are there any difference. EG VS and VR commodores have different badges on the front. Any help is appreciated.
