Taz_Rx
    6792
    53
Everything posted by Taz_Rx
  1. Good place to start... https://www.rollaclub.com/wiki/index.php?title=Main_Page
  2. Yep.... that's all it's about ๐Ÿ˜ Hopefully it doesn't come to that. Although another full bottom end rebuild could correct my balance! ... and give me the opportunity to throw in the other new bits. Last resort.
  3. So long overdue update. Guess I'll be doing what will become inevitable in a lot of backyard garages in the coming months (Hey let's look at the positives) and getting some work done in this!! Where to start... So shortly after run in and the initial tuning I started having some clutch issues. Wouldn't disengage fully making it hard to get into gear (especially grinding reverse) and would also want to nudge forward at the lights etc. Spent months chasing my tail with it getting new master cylinder, throw out bearings, having the fly wheel refaced etc etc etc. Finally worked out it was loose rivets in the brand new exedy pressure plate. Essentially the clamping part of the pp want disengaging parallel to the flywheel causing an edge to drag. After a pretty drawn out warranty process with exedy they finally decided to replace the kit. I can appreciate from there side though that this was: a TE72 clutch kit, mounted to a modified k series flywheel, inside a rare as rocking horse shit bell housing, using TA22 hydraulics behind a motor making about 4 times what it really should! ๐Ÿ˜‚ There's still a little frustration around the situation as I spent a lot of time and moon by trying to find and fix the problem. Also that faulty pressure plate was the one that was balanced and indexed to my rotating assembly balancing for the rebuild. Anyway... I'll install that soon with another t50 I got recently as the current one likes to jump out of 4th sometimes. Head gaskets ๐Ÿ™„ I'm not entirely sure what's going on at the moment. When I rebuilt the motor I used a permaseal head gasket. About 500km or so in that 'blew' and I got the last 2 genuine 5k gaskets left in the country. Stuck one of those in (with the ARP's as well) and it went again not long later. When I say BHG... the only real symptom is when you start it first thing in the morning it'll run on 3... or maybe even 2 because of wet plugs where water has entered the cylinders overnight. Not heaps but enough. This is actually a slight problem a had a few years ago before I rebuilt three engine! I'm weirdly kind of 'hoping' this is a crack in the head, not really blowing gaskets! If it's not that, then it's a possible crack in the block... and that's harder to fix. Pretty sure that may have been found when the machine shop had the block for boring as well. Anyway watch this space. Things happening soon to 'help contain fluids' ๐Ÿ˜ Oh and the contents of that cardboard box is a whole other side project!
  4. Oh and I think st205 stuff is slightly different. There's all 4 different BC's and various other st215 coilovers available anyway.
  5. Haha so true. The ones I got were just cheap universal ones from Repco for $75 and they only take 5 minutes to put on. I do need to get some kind of bike rack to put on them though because of the lack of tow bar situation. Speaking of which, apparently an avensis bar fits but I need to investigate and confirm. Recent camping trip. Boot and half the back seat full. I did manage to also squeeze an 18" park bike in there with the front wheel out hahaha. Only problem with putting the kayaks (or something equally as long) on is the top wing flips up near vertical and tries to snap itself off on your load if you forget and try and open the boot ๐Ÿ˜
  6. So I've been driving this thing flat out lately and loving it. Great practical car and I've got some roof racks for it that are quick to clamp onto the rails. It's had kayaks, pallets, ladders and dining tables thrown on top haha. Did have to replace the exhaust manifold gasket recently as it was a victim of the old #1 blow out that is a known problem on these models. I didn't realise but the exhaust manifold and turbine housing are all cast as 1 piece! Took me ages to work out how to get it all un bolted too... damn Toyota and there over-engineering with brackets on everything. Oh and now thinking coilovers could be back on the cards (funds dependant)... it drives well, but I have now bottomed out the suspension a few times with slightly more spirited driving. So it wouldn't just be cosmetic.
  7. It still ends up too low for turbo. 3k head on a 5k with D's will give you about 7.5:1 CR. Take 100 thou off it and you still won't get it above 8.5:1. If you're using the D's just use the 5k head. Get it surfaced and give it a freshen up.
  8. I wrote this up years ago... https://www.rollaclub.com/wiki/index.php?title=Tech:Engine/K_Series/Valve_Clearances
  9. What suspension is in it? Looks like you've got some lows happening. When I get some new wheels under mine I might need to correct the ride height a little. Had a quick look at kings website lady week and they didn't appear to do springs for these. Don't really know if I can justify BC's. If you're wrecking the while thing I might also be interested in the windscreen add mine has a crack in it. I'm in no great hurry so just keep me updated as things happen ๐Ÿ‘
  10. I can get triple j fine now so I'll happy. Between the sub 90mhz tuner and a 6 stack in dash that would skip if you drove over a grain of sand I didn't muck around on replacing it all. Wiring kit arrived today so I'm currently half way through installing the reverse camera. This is what I got... https://www.ebay.com.au/itm/Kenwood-DDX4019BT-Kenwood-CMOS-130-Reverse-camera-KENWOOD-WARR/123701247763?epid=18034415640&hash=item1ccd2b3f13:g:600AAOSwMs5drk8K Repco stock these. $462 for the head unit plus another $81 for the camera to that was a damn good price. I also got an eBay coupon that saved me another $30. Can you maybe pm me some pics of your interior? And are you just talking seats, or plastics too?
  11. Hmm could be interested in that! Keep me posted. I assume it's not the model with recaros? Installed a new stereo today... so I can now actually tune past 90mhz lol got a Kenwood double din touch screen with reverse cam, Bluetooth etc.
  12. Yep basically all of the drive train is gt4 Celica, including the 3sgte
  13. Can't wait to see this thing ripping up the strip Darren!! ๐Ÿ‘ Maybe you'll get that fastest k in Aus crown! ๐Ÿ˜‚
  14. With the need of something more practical (carting the kid's bikes around mainly) I decided to get myself a new daily. Always wanted one of these since I saw them in NZ about 12 years ago. Been keeping an eye out on Gumtree etc and one popped up recently close to me. 1998 ST215. Manual.... Yes it's actually a manual!! About 200k km but still in really good condition. Couple of mods - HKS exhaust, HKS turbo timer (pre import mods), auto metre boost guage, Turbosmart BOV (which sounds a bit loose and fluffy for my liking) and genuine TRD front bumper. Which to be honest I don't really like that much. There's one little part of it that makes me think it looks like the bastard child of a VT clubsport and an Evo 3 hahaha. You work out what that is. No great plans. Maybe some wheels - Same stud pattern and offset as a WRX so I'll keep my eyes peaked in those circles. Maybe some BC coilovers if new shoes don't look quite right. Then maybe just some practical mods like roof racks and a tow bar if I can source. It's quite nice to drive and has plenty of poke. I didn't know these things ran around 13-14psi out of the box!! And the good old $500 Camry that was bought to get me through when the corolla was defected (3.5 years later) will hopefully get moved on next week. Even though it looks like a piece of shit, it's been ever reliable and been very good to me. Basically haven't spend a cent on it since I've owned it.
  15. All k's take the same rear main I'm pretty sure. You should be able to tell if it's engine or gearbox oil from the smell of it. Gb oil is horrible stinky shit.
  16. Well it doesn't look like it would actually run very well... because there's nothing done to the fuel system.
  17. Is that really poly pipe and duct tape? ๐Ÿคจ
  18. Why not just buy a gasket to use as I template and have a ladder cutting place cut you one? I've done this before with other exhaust flanges and even the copper em30 group buy I once organised.
  19. That build was over ten years ago. Car ram 8's
  20. I'll just leave this here... ๐Ÿ˜
  21. With the rate at which those things spool on a 4k, Stu.... I reckon it'll last maybe 2 or 3 boostings hahaha. I can only imagine the wheel speed. 60rwKW is probably an easily achievable goal. I made 70kw at 10psi with the old tdo4l setup on a 4k.
  22. I'm never going to dis you for turboing a k mate. Instead of the usual 'why bother, just put a 4age in it' comment.... fucking sheep. Just do yourself a favour and don't use anything but a stock cam. Response will be great, but top end a little dismal. Just crack another gear ๐Ÿ˜‰
  23. It's that a ct12? They're a bit too small for a k really
ร—
ร—
