Taz_Rx
    6790
    53
Everything posted by Taz_Rx
  1. Who's wagon? :P
  2. Your welcome to drop in and help tonight if you want mate. Think Andrew is already coming round after work. I'll text you the new address.
  3. Yeah right, you have bugger all clearance. With a 205 I'm obviously going to get 5mm closer but wasn't sure how much deflection I might get. Good point about camber, steering angle etc resulting in not as much deflection compared to the rear. Mine are shockworks base height adjustables for an 86. As i said before I won't get an accurate position of the (preload) adjuster rings until they're in the car and have weight on them. ..which will hopefully be tomorrow.
  4. Is this still going to be a burnout bus? I'm a big rotor fan (and owner) but will admit they're probably not the best burnout power plant.
  5. The man is on the money. That's ''dirt's'' final resting place. Moved house a few weeks ago so had to get the shell out of the old shed. Thought I'd cut the roof off it for some rust repair metal before it went. In other news, plan is to get new coilovers in tomorrow. Just waiting for a couple of little adapter sleeves to bee machined.
  6. Early or late t50? If early it has the same front yoke as a k box!
  7. :(
  8. Here's a couple of pics of my clearance. Note I haven't yet set a definitive ride height on the base adjustment so this may change a bit yet, hopefully may only need to go up so that will give me a bit more clearance.
  9. No rca's? This thread it's rather interesting for me re tyre deflection as I'm just about to fit my new coilovers and am a bit concerned about the amount of clearance I have off the adjuster rings. Currently have 195's stretched over 9's but really want to go 205's on the front.
  10. Didn't happen if we don't see a video ;)
  11. I've got some 27mm bolt on spacers for sale if you want to get them out a bit more!
  12. Not really going to notice it
  13. Fraction lighter but still interchangeable
  14. Didn't even know there was a bmx thread in here. Got the kid into racing now. Was unofficially (no placings) second fastest 6yo in the state titles last year. Rides a redline mx mini, damn it's light!
  15. https://technotoytuning.com/toyota/ae86/steering-knuckles-ae86-corolla
  16. Ah ok. Might not be too bad. Should definitely be responsive, hopefully just doesn't choke it in the top end. Did you see my custom sr20/k dual pulse cas? I'm just about to borrow another motor so I can mock up some brackets for my 4 ls1 coil packs. They're worth looking into if you haven't got any yet. Readily available, cheap and best of all internal igniter!
  17. Btw, what is that custom dizzy/cas?
  18. Diesel?
  19. What turbo is that? It looks a bit on the small side! I personally think a t25 is too small for a worked k.
  20. I believe ohwhatanissanfeeling is using a Commodore master on a 55 booster with his sr. Have a look in his projects thread, I was asking about it late last year.
  21. Less lock and slower steering
  22. Jump forward about 10 pages
  23. Bit too much timing maybe? Guessing you did use a genuine hg either?
  24. Have a look in my projects thread ;)
  25. Surely must be due for an update on this?
