6790 -
53
Everything posted by Taz_Rx
Because pretty much everything was done with 'good engineering practice' there wasn't much at all that needed to change to. All I really needed to do was change the fuel system and address my track issues. Now I can get back onto my other little projects like the sequential injection/quad coils etc.
You running rca's?
There is genuine corolla ones, they came on xx model 55 coupes and some other full spec wagons etc. I used to have a 38 with a/c and a passenger side mirror. Bloody rare though. For a genuine one expect to pay at least $100. She might just have to except aftermarket as you could get a pair for much less.... or go all jdm and get some fender mirrors. :rolls:
That's a k40 not a t40. All you really need to hook up though is the 2 pins coming out of the other side for the reverse lights. Don't worry about the one out the top.
I ended up getting the federals. Didn't have any grip issues I my quick drive for inspection. Can't wait to give them a good test out in some twisties!
Would have hoped to had it sorted by now. Mod plate inspection was done back at the end of July before I went off on tour, just waiting for it to all be approved and plate issued. Problem is all the rules changed at the start of September so transport was inundated with 80 odd applications of people getting in before the rules changed. My application is still sitting amongst that backlog. I haven't spoke to Steve about it for about a month now so I'll follow up again soon.
In launy at the mo. Come round tomorrow or Thursday night.
Oops forgot top reply to text. Think 27mm would be too much too
What exactly is noisy? It might just be an axle bearing which is relatively cheap and easy to fix.
No not just swapping the calipers.... backing plate too. Then the caliper will be on the front of the disc (where it is on a 55), clear of the steering arms and the bleed nipple will still be on the top.
They are 55 girlock calipers..... which are on the front of the disc on a 55. Swap them over left to right and you will have ample room.
Good to finally meet you too mate! Mmm ribs
So calipers are on the back of the the discs?
Auto probably wouldn't help the situation
82 starlet would be fwd. You need to look for one from a kp starlet
I had a conversion about it years ago with a mechanic (who also raced) he said you don't need to stress until you're up around 120-130 degrees. I did see that a couple of times with some spirited hills driving so eventually hooked up my oil cooler. Now I don't get any higher than water temps. Volume would also make a difference in how hot you get.
Ke3X-5X Silvia Struts & Brakes Upgrade?
Taz_Rx replied to MichaelR31's topic in KExx Corolla Discussion
Skyline 4 pots are essentially identical to the sumitomos on a s4/5 rx7, just with a different manufacturer cast onto them. ... ie just get some ajps brackets! -
Bare in mind that going from +12 to 0 will give you obviously 12mm more poke, then going to an 8 will stick it out another half inch.
We (aus) can get RB in 4x114..... https://www.rotawheels.com.au/wheels/rota-rb
Ke55 / Ke70 Gurus... Some Front Brake Questions
Taz_Rx replied to rollababe09's topic in KExx Corolla Discussion
What car is this for? 55 backing plates are the same as 30. Early 55's had the same calipers as 30's the later had girlock calipers the same as 70's. 30 rotors are also the same diameter as 55 but 2mm thinner. -
Ha. Put another blouse on lol. I can tell you that when I put my k-t in the original cable slotted straight into the Speedo drive. Haven't got my w50 any more but pretty sure that was just the same too though. You'd need a matching set of gears though and the output shaft on the w box would no doubt be bigger so the gear would be loose on a k shaft.
Yeah I was quoted $140 for the 195s, you can get them four $111 off eBay but then need to pay freight. The achilies are $145.
Ok so little bit of an update. Have my approval in principal back, only thing I got pulled up on was tyre size. Due to "sectional width" I'm only aloud to run a 205/45/R15 (which doesn't exist) or a 195/50/R15. In which case I'll throw some semi clicks back on so will either be some Achilies 123 or maybe some Federal 595 RSR. If anybody has feedback on either I'd like to hear it. Just finished off my new fuel system. Now consists of a original tank with aftermarket level sender, Carter 4070 lift pump with an aeroflow reusable filter, aeroflow surge tank, Bosch 044, and all line/fittings in aeroflow -6. Things didn't quite fit how I originally planned so there were a few changes in configuration. While I had the boot all stripped out I gave it a coat of primer and some textured under body sealer for durability. When I fix some little rust holes in the lower rare quarters I'll paint the rest out too. Also made up a new panel for behind the tank, scored the material free from work. Its maybe a little to shiny but the price was right. For ease of mounting I also made up an alloy plate which the surge tank and 044 mount to. That tidied things up nicely too. Stripped.... Primed..... Underbody on.... System all finished.... Just waiting on some wheels to arrive now and then I can get my inspections done.
