Hi, I'm Clyde, 20, from the Philippines. First of all, I don't have a KE70, but I do have a 9thgen Corolla with a 1ZZ-FE and had a 4A-FE AE92 DX. I'm here to ask on how to build the 7K engine from my Tamaraw FX/Kijang, it has a 7K-C much like the pre-'99 Lite-Ace from Australia and the KE70s you guys install it in. I'm decided to get the engine built-up by the end of November if I get the right parts... My plans are to PnP the head, new valve stems and springs, maybe change compression to 9.5:1, replace the cam to a better one, adjustable sprockets, upgrade the ignition to an MSD Coil, a better mapped and more stable distributor and high-tension wires, 4-2-1 headers, straight exhaust or at least have a huge resonator and a 4" pipe at the end, twin sidedraft 40 carbs, make a custom linkage for it and make the alternator 120-160A.
I expect the 4K manifold for the Weber40s to fit, I'm not sure if it's the same, I need your input here for compatibility. Anyway, I'm hoping to get it to rev past 6,800RPM and still be torquey since it's for a truck. Can I get some input on how to make this plan work? I have the budget to make it work, but I'm not really good on the K-Series so I really need some help from the gurus. I need some answers on which cam to get, which distributor and what timing curve to use, what would be a a really good comp-ratio with Octane93-96 leaded petrol, and how do I get the engine to stay cool at severe traffic. I just need some extra advice on how to do the build, I already read up on the how to build a good K-Series engine, but most of them are 4K and 5K applics. So please help on this 7K thing.
Thanks a lot guys!
