Mad55
    28
  • Real Name
    Chris
Mad55's Achievements
  1. Mad55
    My Ke55
    after driving it for a while a bolt came out the turbo flange, and now theres a massive hole in the manifold gasket and it shoots flames from there when i back it off so ill have to pull it apart again and change those gaskets. What a shit job that was last time... ah well, the joys of having a car i guess ;) oh and it was making about 80kw but now its only running at 3 or 4 pound due to the gaping hole in the gasket haha
  2. Mad55
    My Ke55
    goes fairly well, getting better the more i drive it but only running 7psi because it keeps leaning out at around 9 but I'm happy with it :) pulls hard on boost and sounds awesome haha just need to put the rest of my guages in and then start on the body work
  3. Mad55
    My Ke55
    it comes home mondayyy :)
  4. Mad55
    My Ke55
    was going alrigth but its not quite done yet, the mechanic is a lazy bastard. but when it was on there it was leaning out on 9psi so it still needs a bit of work
  5. Mad55
    My Ke55
    and on the dyno
  6. Mad55
    My Ke55
    just a couple of interior shots
  7. Mad55
    My Ke55
    so its taken about 4 weeks longer than expected because the tuner is having trouble with it :( but he reckons it will be done this week so far theres been the coil, alternator and now its the fuel feed from the tank as it is too restrictive for my fuel pump and leaning out at 4psi but once thats changed it should be all go... will have an update on how it goes when i get it back...
  8. hey, was considering dropping the 4k turbo idea and going for a little bit more power ;) want to know if anyone has put a 1jz or 2jz into a corolla before or thinks it will fit any advice or help is appreciated thanks
  9. Mad55
    My Ke55
    ill know how it goes on friday the 11th :D so ill put results and dyno sheet up then. can't wait
  10. Mad55
    My Ke55
    got it 90% back together today, will have it finished on the weekend then i just have to wait for my MSD timing control bos to come in and it will get tuned :)
  11. Mad55
    My Ke55
    yeah it was 4 spd but now its 5spd :) getting a respray in the next few months too. now for an update... took the head into the engine works place and got it cleaned up, valves reseated, all the seals done (used the original head because i knew it wasnt cracked or anything rather than wasting time on the shit looking purple one lol) i noticed the two heads were different which u will see in the pics that there is a shoulder around the valves on and the old one is flush the engine guy said it looked like a 3k head so let me know what u think ;) over all I'm pretty happy with the way it looks just need a new set of head bolts and ill put it back together and turn the key and hope for the best anyway here are the pics
  12. Mad55
    My Ke55
    head gasket :(
  13. Mad55
    My Ke55
    locked the dizzy but didnt check the timing :hmm: where should i set it to? was set right before dizzy was locked but would locking it change the timing on idle?
  14. Mad55
    My Ke55
    yea ill give it a look when i get the chance, hopefully it is just the seal but not looking good so far
  15. Mad55
    My Ke55
    took it for a spin after gasket was changed was going much better and staying on boost and i pulled up the drive and was just idling and then white smoke started pouring out the exhaust, so it looks like head gasket but ill have a look when its cooled down :( its always one thing after another. losing my patience with this car very quickly.
